Sep 14, 2019, 06:39 PM
A man with too many toys
55 lb +
Thinking of building a giant scale airplane.
What's the procedure for flying heavier than 55 lb airplanes for recreational purposes?
Sep 14, 2019, 07:58 PM
vollrathd's Avatar
First on the list, buy 30 pounds of batteries!
Giant Corvus Model (This one weighs 23 pounds)
https://www.rcgroups.com/forums/show...-Models-Corvus
Sep 14, 2019, 08:52 PM
You'll want to check the governments "drone laws", but I don't think the govt. addresses weight other than if you fly an airplane larger than a hummingbird (my interpretation) which means you have to register yada yada yada.
As far as the 55lb+ category, it has always been in the AMA's rules and regs as to how that works.
It's all here: https://www.modelaircraft.org/sites/...iles/520-a.pdf
Sep 14, 2019, 08:54 PM
earlwb's Avatar
Well to be legal and all you need to get the 55+ pound plane certified through the AMA Large Model Airplane Program. Then you may or may not need to register with the FAA, but basically you have to register via paper work not online with the FAA. It gets uglier with the FAA if you are being paid to fly the RC planes or drones that are that big.
But since there are quite a few folks flying really big RC planes, it can't be all that onerous to get setup for it.
ref https://www.modelaircraft.org/sites/...uments/100.pdf
ref https://www.faa.gov/news/fact_sheets...m?newsId=22615
ref https://www.flitetest.com/articles/f...gistration-faq
ref https://www.pumphreylawfirm.com/blog...one-55-pounds/
Sep 15, 2019, 05:17 AM
Looks like you just have to fill out an inspection form each day before you fly and you are good to go.
Sep 17, 2019, 11:04 AM
GWRIGHT's Avatar
for AMA insurance to cover you, their program has 2 levels with various requirements. 55~77 lbs and 77~125lbs. Currently, 125 is the absolute maximum for AMA to recognize it for insurance purposes. Numerous requirements, such as inpection (AMA has specific inspector), maximum thrust (If I remember correctly it's the LOWER of either aircraft weight plus 5 lbs, or 77 lbs for the first category, and change that to 90 lbs for the larger category. There are also minimum servo torque requirements, and how to compute them is documented on AMA's site. So,.. build, have AMA inspector go over it and watch it fly, assuming you've met the other qualifications. As for FAA registrations, if it's above 250 grams and under 55, just register and put your number on the plane. Over 55 is not a small unmanned ariel system according to them, so technically you'd have to register it the same as a manned aircraft with tailnumber and such. However, they've not enforced that ,..........yet.
Latest blog entry: blog
Sep 17, 2019, 03:37 PM
All great reasons to keep that sucker at 54lb, 15.9oz.:
Sep 17, 2019, 06:06 PM
Does anyone know why the FAA chose such an odd-ball number
Why not just 50 lb or 100 lb?
Sep 19, 2019, 07:10 AM
Does anybody know why bureaucrats do the things they do?
Whenever those inside the beltway issue another fatwa to we peons, it is not our job to question our betters. After all that's why they are there in the first place: because they know what's best for us.
If they weren't there, then all of civilization would collapse and fall into....well, anarchy and people would have no idea what to do next.
And of course, it's all to keep us safe.
Sep 19, 2019, 07:45 AM
Multi-Platform Pilot
barracudahockey's Avatar
Because we are the last last people on the planet not to convert to metric.
To the reset of the world the FAI uses 25 kilograms which converts to 55 pounds.
Sep 19, 2019, 08:21 AM
It's not the bureaucrats fault.
It's the people who vote for them.
That said, don't blame me. Blame the party that brings you this.
Sep 19, 2019, 10:03 AM
The general public just does not like radical ideas like converting to the metric system or taking away your play things (drones and guns). They tried to change the speed limits to metric in the 70's but that was rejected by the public. It's human nature to appose change.
We should have a law that says you must live with all the laws that were in effect they day your were born and no new laws would apply. That way you know the rules and can plan your life accordingly. The way the FAA keeps flip-flopping and making up random rules and not enforcing some makes it hard to know what's actually legal and what's not. First you had to register, then the courts said that it was illegal for the FAA to make you register, them they say you must register again - the whole process is crazy.
Sep 19, 2019, 11:09 AM
Bureaucrats are NOT voted into their office. They are unelected government apparatchiks.
Sep 19, 2019, 01:16 PM
They are appointed by those that ARE voted in.
Same thing. Elections have consequences.
New Product 300 lb. PAYLOAD VertiPod Hex commercial drone Pete Bitar Commercial UAV/FPV 1 Apr 05, 2016 01:10 AM
Rant Ultralights: 600+lb GVW, 100+mi range -- no FAA registration bmw111 Model Aircraft & Drone Advocacy 13 Dec 23, 2015 12:03 AM
Question 40% cub on floats 55 lb. waiver? CarPainter Giant Scale Airplanes 1 Feb 07, 2011 10:39 AM
Discussion 100 watts/lb = ? ounces of thrust/lb cloud-9 Power Systems 20 Jan 03, 2008 10:58 AM
Discussion 55 LB Glider certification -High Speed pass - no energy marios Scale Sailplanes 47 Oct 17, 2007 08:13 PM
