This thread is privately moderated by Bchirrick, who may elect to delete unwanted replies.
Sep 13, 2019, 02:43 PM
Trader Rating: 63
$125.00 USD
Buyer pays shipping
Sold
Wi-Fi CG Scale XXL
Use your phone, tablet, computer, view CG and Weight of your model. Save multiple models, change settings, etc. Power supplied by your micro usb cable.
More info:
https://www.rcgroups.com/forums/show...Wi-Fi-Cg-scale
Will accept,
150mm front post to rear pad, cg of the plane you are measuring should be less than 150mm
150mm max fuse width
70-72mm bottom of wing to bottom of fuse. You can increase this by adding taller foam, felt pads on existing plastic pads.
Will measure 15-20 lbs
Very accurate for lighter dlgs also.
Shipping is $15 ConUS
Calibrated and tested
Easy operation
CG Scale (1 min 18 sec)
Sold Wi-Fi CG Scale Bchirrick Aircraft - Sailplanes (FS/W) 0 Jun 07, 2019 01:21 PM
Sold Wi-Fi CG Scale Bchirrick Aircraft - General - Miscellaneous (FS/W) 0 May 24, 2019 07:39 PM
Sold Wi-Fi CG Scale Bchirrick Aircraft - Sailplanes (FS/W) 0 May 16, 2019 11:17 AM
Sold Wi-Fi CG Scale Bchirrick Aircraft - Sailplanes (FS/W) 1 May 11, 2019 05:49 AM
