1/10 Capra 1.9 Unlimited Trail 4WD Buggy Kit (AXI03004)
The Axial Capra 1.9 Unlimited Trail Buggy Builder's Kit for advanced drivers is engineered for cutting-edge crawling, with portal axles plus a transmitter-operated DIG function that allows a tighter turning radius. Add your choice of electronics.
From Horizon Hobby...
The Axial Capra 1.9 Unlimited Trail Buggy Builder's Kit is a "new from the ground up" design that any advanced RC enthusiast eager for cutting-edge crawling will appreciate. Its Currie F9 Portal Axles provide extra ground clearance at the diff pumpkin for the best crawling performance. With the included Dig transmission, you can also switch on the fly between 4WD and FWD directly from your 3-channel transmitter locking the rear axle whenever you need the tighter turning radius of front drive power. The Capra features a realistic tube chassis design and metal gears everywhere, from the center transmission to the lockers and portal axles. It rides on licensed Raceline 3-piece molded beadlock wheels that can be fitted with whatever 1.9 tires you prefer. For pioneering performance in an RC trail buggy kit, choose the Axial Capra.
Axial AXI03004 Capra™ 1.9 Unlimited Trail Buggy Builder’s Kit (3 min 21 sec)
Features
  • Newly designed transmission with Dig function enables a tighter turning radius by locking the rear axle for FWD power only.
  • Currie F9 Portal Axles increase ground clearance at the diff pumpkin for the best crawling performance.
  • Includes all-metal gears, from the center transmission to the lockers and portal axles.
  • Tube chassis design offers optimum clearance plus realistic scale looks.
  • All pivot points are on stainless steel balls for a durable, long-lasting suspension point.
  • Includes injection-molded, 3-piece, licensed Raceline beadlock wheels.
  • Adjustable oil-filled shocks feature hard anodized, threaded shock bodies, a single coilover spring, and a cap with a bleed port.
  • All-metal front universal axles provide smooth action and 45 degrees of steering angle for an efficient, high-performance drivetrain.
  • Durable, machined aluminum universal.
Photos
Learn More!
For pricing and more information head over to Horizon Hobby!
Sep 22, 2019, 08:07 AM
USA: LakeGeorge, New York
Wow...looks high end. No upgrades necessary
Latest blog entry: My FAVORITE FPV CockPits'!!!!
Sep 22, 2019, 11:51 AM
with axial there are always upgrades necessary
Mini-Review LRP S10 BX BL Blast 2 RTR 1/10 4WD Brushless Buggy Now $136 9/18/2018 fastmax Off-road Cars 100 Sep 12, 2018 05:59 PM
Discussion Schumacher CAT XLS "Masami" 1/10 4WD Off-Road Buggy Kit - Re-release Jym73 Off-road Cars 14 Jul 20, 2017 01:15 PM
New Product BSR Racing BZ-444 Pro 1/10 4WD Racing Buggy (Un-assembled kit, ARR) Jym73 Off-road Cars 91 Nov 02, 2016 12:12 PM
Discussion Motor for 1/10 custom 4wd buggy/truggy fossil1999 Electric Power Cars 13 Feb 03, 2016 01:28 AM
Discussion 4wd slash owner, now which 1/10 4wd buggy? mc_heli Off-road Cars 0 Feb 23, 2010 09:36 PM
