Sep 12, 2019, 08:19 PM
Jetfan 80 on 8S-9S-10S HET 700-68-1400kv
Anyone know what kind of amps this would draw? I'm using a 90amp ESC and would like to limit amps to 90 max. I'm guessing 9S should be close maybe 85amps?
Lipo will be a Turnigy Graphene 45C
Sep 12, 2019, 10:22 PM
I agree that is the ballpark but I am basing that on the 1865kv motor on 8s. Even on 7s the 1865 would be over 100A. Be sure the controller can handle the high voltage. I have a castle 130A controller but only good to 8S for my 1865 motor.
Sep 13, 2019, 05:00 AM
Gorilla Glue Expert
PikeStaff's Avatar
https://static.rcgroups.net/forums/a...05-3-image.jpg
JFís testing shows the 700-68-1400kv to be 88a on 10s. Didnít look any deeper - you can do that.
Their fan charts are decently representative of real-world results.
Sep 13, 2019, 09:29 AM
Thanks I think that chart may be reading a bit low.
It shows the 1738kv on 8S at only 89amps. I had that setup, if memory serves it was in the 100-105A range.
Edit: probably comparing bench vs. Installed, looks like amp are 10-15% higher installed.
Sep 13, 2019, 11:27 AM
Definitely. The charts are never in-airframe. Once in a real airframe, their are ducting losses and current shoot up 10-15% as mentioned.
A 100 A controller might work...Castle's have some head room...so I would run a Castle 100A even if peak amps at WOT is 102A. But I don't think
my Castle 100 is good for more than 8S.
Sep 13, 2019, 06:49 PM
I'm using a YGE 90 HV
Will try on 9S. Hopefully that will be safe. Probably can't support more weight anyway as I'm right at 1KG in lipos.
Sep 16, 2019, 07:43 PM
Well flew it tonight. Not as fast as a 1738kv on 8S, but not much slower either.
Amp draw on 95% full lipo's was a suprisingly low 71amps Flew 4mins with only 3300mah in lipos (9 cell)
This is a nice efficient setup, easy on the lipos, motor, ESC etc. 10-11S is also an option.
Sep 16, 2019, 08:26 PM
Gorilla Glue Expert
PikeStaff's Avatar
.........This is a nice efficient setup, easy on the lipos, motor, ESC etc. 10-11S is also an option.
Mmmmm.....indeed. Maybe that 88a JetFan result wasnít so far off the mark.
Sep 17, 2019, 08:19 PM
Yes, i test fit a 10S 4000mah 45C pack.
It fits, just barely. 1.2KG but I believe the airframe can handle it. on 9S ~2300watts it was doing 125-135mph.
10S should be 145mph+ at a still very reasonable ~85amps
Video on 9S, fan seems to be nicely balanced:
September 17, 2019 (3 min 46 sec)
Sep 17, 2019, 09:26 PM
Ok on 10S i saw 87amps peak but at 3300watts!
2 X 5S 4000mah 45C Turnigy Graphene .
Should be properly ballistic now, will test fly in the next couple days.
AUW 8.3lbs
Sep 18, 2019, 09:24 AM
Gorilla Glue Expert
PikeStaff's Avatar
Mmm boy!
Going pretty good in your video - it is sure to keep your interest in it when flying. And if you do decide to give 10s a turn, please tell your cameraman to keep the zoom off for the recording.....itís gonna get a bunch harder to keep track of.
Best wishes for all you hoped for.
Sep 18, 2019, 10:04 PM
Thanks. I'll see what i can do. Cameraman may demand a better camera and a raise in pay
Sep 22, 2019, 09:43 PM
Lee Liddle
Knife Liddle's Avatar
Tell him you'll double his pay, or even tripple it.
Oct 02, 2019, 10:20 PM
10S Flight:
E-Flite Habu32x 10 Cell Big Power Setup (3 min 6 sec)
Oct 10, 2019, 12:36 AM
thats moving
Discussion Jetfan 90, HET 700, Castle 120 help! Tronn Electric Ducted Fan Jet Talk 10 Jun 15, 2017 09:28 AM
Discussion Opening HET 700-68 motor Benovitch Electric Ducted Fan Jet Talk 2 Jul 25, 2016 12:44 AM
Help! het 700 series 700-68 1865kv mcfudd Electric Motor Design and Construction 1 Jul 16, 2013 03:27 PM
Discussion Data for HET 700-68-900kv on 12s in sm 90 stumax? jacojet Electric Ducted Fan Jet Talk 0 Dec 05, 2012 03:13 PM
Help! Het 9305 with 700 series on 10s whats the best kv option? egall232 Electric Ducted Fan Jet Talk 3 May 01, 2011 03:55 AM
