Usually the number of frame losses is approximately equal to (or even slightly less than) the number of fades for other Spektrum diversity receivers. chris |
chris |
My setup is showing dBm. I'm using the AR637T with a DX9 on AirWare 2.05, US versions.
That -40 dBm reading in the screen shot was taken with the transmitter practically on top of the plane. You want it to be as close to 0 as possible, and I'd say -40 is about as close as you're going to get. As the signal gets weaker, it will become bigger negative numbers (-50, -60, etc.) There will be a point where the signal is so bad that the receiver has a hard time picking it up, but I'm not sure where that point would be exactly for these receivers.
My recommendation is to run TX firmware 2.05, go into the Telemetry page in settings, click Flight Log, scroll to the "dBm" entry, and change it to %. We tried to make a % range curve that is more intuitive than dBm. Matt |
Never mind my previous post, I figured it's in the Flight Log setup.
I just created a new model and bound it to an AR637T and made the pictures below. In the Telemetry Menu, select Flight Log. See picture 1. On the Flight Log Setup screen, select either dBm or %R units. See pictures 2 and 3. (The default setting was dBm.) The results show as pictures 4 and 5. Andy |
In my Range Test screen, always dBm is shown, and additionally either RSSI % or Range %R, depending on the selected unit. Now the question remains: do your signal strength values vary in the Range Test screen if you change between "FULL POWER" and "REDUCED POWER" by pressing the Bind switch labeled I? chris |
Discussion | We(Flyingroup.com)are here.We are waiting. | Flyingroup | Vendor Talk | 1 | Aug 25, 2016 12:01 AM |
We(Flyingroup.com)are here.We are waiting. | Flyingroup | Vendor Talk | 0 | Aug 21, 2016 11:45 PM | |
Cool | the new phone books are here the new phone books are here! | hoser | Electric Ducted Fan Jet Talk | 9 | Mar 24, 2011 09:28 PM |
Discussion | the Logos are here ! the logos are here !!! | dutchydawg1 | Slope Soaring | 29 | Mar 13, 2011 11:02 AM |
The new T3DIIs are here!....The new T3DIIs are here! | navyflier | Parkflyers | 1 | Oct 23, 2003 07:36 PM |
