This thread is privately moderated by kydawg1, who may elect to delete unwanted replies.
Sep 11, 2019, 04:30 PM
Trader Rating: 90
"Aircraftus Fragmentum"
kydawg1's Avatar
$59.00 USD
Seller Pays Shipping
For Sale
REDUCED - BNIB - RunCam Split Mini 2 FPV / HD Camera DVR 165 deg FOV
2X Brand new - never removed from box -
These were bought my me to use in new builds.... now I do not need them, so time to give someone a great deal.
Adult owner, non smoking home.
You get the exact item(s) shown in the photos.
$59 EACH ($10 less than retail) or both for $114 shipped CONUS.
Paypal accepted, will ship within 2 days with tracking. No trades.
Specs below............................................
The RunCam Split Mini 2 is an amazing FPV/HD recording camera that allows you to capture crystal clear 1080p video at 60fps without the need for a bulky action camera. The Split Mini 2 keeps the same small camera form factor (19x19) as the original Split Mini. The big difference here is the PDB. Instead of two boards the Split Mini 2 now comes with only 1 PDB!
To cram all of its components into one, they made the PDB a bit thicker and wider, but without the need for standoffs, the overall height and weight are much smaller! This will allow you to fit the RunCam Split Mini 2 on even smaller quads than ever before!
Features
1080P/60fps HD recording & WDR FPV camera
Power-off protection for video files
Ultra lightweight (12.5g)
Low latency TV-OUT (40ms)
Wide voltage (5-20V)
Anti-drop SD card
FPV aspect ratio 16:9/4:3 switchable
19x19mm Camera size
Modular Design: Replaceable Lens and manual focus supported
Specification
Field of View (FOV) FPV 130 / Recording FOV 165
Video Resolution [email protected] / [email protected] / [email protected]
Video File Format MOV
Image Resolution 2 MP
NTSC / PAL Switchable
Micro USB Connector
Supports Micro SD Card up to 64G (Require Class 6 or higher, Recommend Class 10 / UHS-I / UHS-II / UHS-III)
PCB Mounting Pattern: 20*20mm
Dimensions: PCB 29*29mm / camera width 19*19mm
Supports Input Voltage of 5V 20V (2S to 4S)
Current Draw: 650mA @5V / 270mA @12V
Weight 12.9g
Package Included
Split Mini 2 Camera
Micro-to-full-size mounting bracket
Metal Cover for protecting the micro SD card
1 Set of M2 screws
3-PIN 1.25mm JST Silicone Cable (female)
3-PIN 1.25mm JST Silicone Cable (male)
3-PIN 1.0mm JST Silicone Cable
Manual
Sep 13, 2019, 08:17 AM
Trader Rating: 90
kydawg1's Avatar
Price Drop - $10 less than retail.
$57 each if you buy them both ($12 less than retail each).
Sep 13, 2019, 09:09 PM
Trader Rating: 1
Hello.
Will you take 30 for one?
I will pick up.
Thank you.
Sep 14, 2019, 06:08 AM
Trader Rating: 90
kydawg1's Avatar
Pick up... $50.
Sep 16, 2019, 07:31 AM
Trader Rating: 90
kydawg1's Avatar
Both still for sale.
