Sep 16, 2019, 02:42 AM
Aussie freezing in Holland
HK TL2000 Takeoff crash (5 min 45 sec)
Sep 16, 2019, 03:22 AM
Problem is float attachment
The floats can move in all directions. Only 1 screw. Floats can move back and forth and sideways.
Solution is to bend up another 2 aluminium strit's. Make them 50mm overall wider and bend the ends flat . Drill 2 hole's, cut the upright plastic off the floats and mount with 2 screws on top of floats .
Or
Make a wider set of struts and add a cross bar to stabilise the floats.
Weight is 100grams
Other floats 200 grams.
Better to save weight and use these with a better attached strut.
I will cut down tundra floats and make new struts similar to standard.
Only add 50gram or less. Or use standard floats with better stronger wider struts.
The grey paar are perfect but 100grams too heavy.
Sep 16, 2019, 01:44 PM
Received and flown today. Good looking and excellent flyer. I will use it on solid grounds only ... however, because of the rather bad condition of our grass runway, I will replace the small wheels by bigger ones.
Like to hear more from you.
Kind regards,
Robert R.
Sep 16, 2019, 03:32 PM
Kind regards,
Robert R.
Check motor mount screws and be careful of the rudder and front wheel servo connection. They weren't as tight as they should have been.
Hoping to maiden on wheels this week.
Sep 18, 2019, 06:03 AM
Great ground plane. 5min flight time
Front steering is a bit wobbly for and aft.
But....
All in all a top little plane to fly.
I have full throws on everything.
Flaperons work fine.
Rudder servo changed to 2 connectors and the main rudder moved to the end of the servo giving great rudder authority in the air and on the water.
Next job is to get a 2200 3s into the cockpit to give a bit more weight in the wind and longer flight time and make the floats better.
Sep 18, 2019, 08:46 AM
Maiden on wheels
HK TL2000 grass maiden (5 min 55 sec)
Sep 18, 2019, 09:58 AM
New float struts
Bending up the new float struts.
A bit wider. Same height.
Drill 2 holes and screw down onto floats.
Use servo screws with a flat head.
Total weight added. 36grams. Double the original struts
Sep 19, 2019, 03:07 PM
Just my 2 cents:
I have mounted bigger wheels. Nose 45mm:dia16mm(was 37x13mm) Main gear: 64dia.x 24mm( was 44x15mm). Now take-off and landing is no longer a problem.
Weight w/o battery is: 780 gms, 3S1300mAh battery 115 gms, total: 895 gms (Amazing because less than advertised)
Amps draw in flight: abt. 7.7 Amps. Power to spare!
Sep 19, 2019, 03:57 PM
Just my 2 cents:
Just watch the nose wheel assembly. Mine was wobbly on the engine firewall so I added some some hotglue.
Sep 19, 2019, 04:21 PM
FoxProGT's Avatar
I'm on the edge of ordering this model.
Does it look like a 2200 would fit in this plane?
Sep 20, 2019, 02:17 AM
But....
Yes ..but CG ? Cant get it back far enough because of the wing spar might need weight at back?
My next job is to cut a hole between the seats for a 22003s and put a fpv camera in
Sep 20, 2019, 03:13 AM
FoxProGT's Avatar
My next job is to cut a hole between the seats for a 22003s and put and fpv camera in
Is the plane significantly nose heavy with the 2200?
Sep 20, 2019, 03:48 AM
Originally Posted by foxprogt
is the plane significantly nose heavy with the 2200?
yes
Sep 21, 2019, 02:48 AM
Flying time: approx. 12mins
Which battery are you using? Did you measure Amps draw at 3 cells?
Thank you.
Sep 21, 2019, 11:43 AM
Thank you.
The 12min was on the HK site.
Its bull .
5min max with the recommended 1300 3s
Go slow on a 14003s to get 6min
New Product H-King Cessna TTX EPO Plane 1100mm (43") (PnF) Andy852 Scale ARF/RTF 4 Sep 03, 2019 05:52 PM
News H-King Voltigeur MkII 3D EPO Aerobatic Plane Jason Cole 3D Foamies 35 May 31, 2019 01:55 PM
Discussion H-King Cessna 182 Skylane 965mm (38") EPO PNF aeronca11AC Electric Plane Talk 0 Oct 01, 2018 05:23 PM
New Product H-King Cessna Skylane 965mm (38") EPO PNF Andy852 Foamies (Kits) 6 Dec 28, 2017 11:03 PM
