Sep 11, 2019, 04:23 AM
slats move, slots don't
New Product
H-King TL2000 EPO RC Plane 1160mm (45.7") (PnF) w/Floats
This looks interesting, wheels and floats!
H-King TL2000 EPO 1160mm - HobbyKing Super Daily (2 min 33 sec)
The H-King TL2000 EPO RC Plane (PnF) is a fun plane to fly and has both wheels and floats so you can fly off land and water. The wingspan is 1160mm so it can easily fit in your car for transport to your favorite flying areas. It is built of tough EPO foam.
The TL2000 is a single-engine, two-seat ultralight which was designed in the Czech Republic. It first flew in 1997. It is a low wing monoplane with a large bubble canopy for excellent visibility.
The H-King TL2000 comes with motor, ESC and servos pre-fitted to make assembly easy and very quick (approx. 10-minutes). All you need to supply is a battery and Radio system (TX/RX).
The powerful 2838-1500KV motor combined with a 3-blade prop has lots of power to do exciting aerobatics like loops and rolls. The model comes with a set of floats to make it even more fun to fly off water when you have had enough of taking off from land.
The H-King TL2000 is a get deal and comes at the best price. Get out and get flying.
Features:
• Lightweight EPO foam fully molded with scale detail
• Detail cockpit including an instrument panel and factory-applied decals
• Quick 10-minute build time
• Efficient 3-blade propeller
• High power to weight ratio
• Water floats and rudder (included)
• Assembly hardware pack (included)
Specs:
Wingspan: 1160mm
Length: 888mm
Weight: 1020g with floats, 940g with landing gear
Material: EPO
Flying time: approx. 12mins
Motor: 2838 1500KV outrunner
ESC: 40A BEC 3A
Servos: 9g digital servo (4pcs)
Prop: 8x4.5 3-blade
Landing gear: Aluminum
Requires:
1 x 4Ch Radio System (TX/RX)
1 x 1300mAh 3S Lipo battery
https://hobbyking.com/en_us/h-king-t...160mm-pnf.html
Sep 11, 2019, 04:40 AM
What's with the civilian plane craze at HK?...
To those whose boat it floats, OK. But to me.., geeze, snore....
Sep 11, 2019, 04:45 AM
At least it is not a warbird for change.
Always good to see something a little different and it is a compact size to fit in the car with wings on!
Sep 11, 2019, 06:12 AM
AndyDodson's Avatar
@OP Andy This looks interesting, wheels, floats and flaps!
Where's the indication that this model has flaps ? I don't see any indication of flappage. Looks good though.
Sep 11, 2019, 06:54 AM
Good point! Now I realise that it is a typo from Hobby King, and should read floats, not flaps.
Oh well, I was looking forward to flaps!
Sep 11, 2019, 06:00 PM
Waiting to see water video and......
Sep 11, 2019, 06:18 PM
DFS#000178
Rampage's Avatar
It looks like it has full-span ailerons so flaperons are definitely an option.
Sep 11, 2019, 06:42 PM
Aussie freezing in Holland
Yep. Only 4 channel. So flaperons it is.
Ordered.
Sep 11, 2019, 07:05 PM
I will be floating it from my boat as soon as it gets here. Wheels too small. Only buying because of floats.
Also see if it can handle 4s.
No indication of flight time on 1300 3s anywhere?
Sep 11, 2019, 09:52 PM
AndyDodson's Avatar
Flaps are always fun, particularly for slow flying but at this plane's weight I'm sure it won't need them. I've ordered one and it'll be interesting to see how it likes the water. I've tried various flap settings and CG changes but I've found with my Tundra that 4S is handy to get it off the water if it's too calm.
Sep 11, 2019, 11:04 PM
FoxProGT's Avatar
I like it!
Sep 12, 2019, 10:05 AM
Just got the new HK Cessna TTX. Might consider this one too because of the floats. Nice to see HK going with some of the more unique scale planes out there.
Sep 12, 2019, 10:30 AM
i already have the 1400 version. but no floats
Sep 13, 2019, 03:45 AM
Sep 13, 2019, 10:58 AM
Where to put rx
Not much room.
Will work it out and maiden tomorrow.
Prop need a little balancing. The screws in the wings didn't line up perfectly but went in OK.
Plane looks good but the cockpit should have been used for battery and rx instead of underneath. I would maybe not have bought it if I had seen that. Maybe ..it's hard on the boat to turn the plane over every time to take battery out. And no bloody room for the S6R.
New Product H-King Cessna TTX EPO Plane 1100mm (43") (PnF) Andy852 Scale ARF/RTF 4 Sep 03, 2019 05:52 PM
News H-King Voltigeur MkII 3D EPO Aerobatic Plane Jason Cole 3D Foamies 35 May 31, 2019 01:55 PM
Discussion H-King Cessna 182 Skylane 965mm (38") EPO PNF aeronca11AC Electric Plane Talk 0 Oct 01, 2018 05:23 PM
New Product H-King Cessna Skylane 965mm (38") EPO PNF Andy852 Foamies (Kits) 6 Dec 28, 2017 11:03 PM
