Sep 11, 2019, 12:14 AM
Inlaying LED strips into foam surface.. Anyone done it?
Hi Gang,
Anyone ever inlay LED strips into foam wing and fuse surfaces? I'm contemplating doing this to keep aerodynamic disturbances to a minimum, on a 54" foam 3d plane.....as opposed to just laying them on the surface....I'm wondering if heating and pressing into the foam with a metal die the width of the strip will let the foam depress...?..., then clear packing tape on top ... looking for a clean install...Any tips clean install or not are welcome and appreciated..
Sep 16, 2019, 09:58 AM
Registered Foam Abuser
jiggiba's Avatar
I used a dremel with the router attachment. Cut a channel and mounted the LED's facing inward. Came out great.
Sep 16, 2019, 02:20 PM
Ok that looks outstanding!!! A+++
What plane is that?
Do you have any daylight close up pics showing the LED install ?
Sep 18, 2019, 07:09 PM
Always in the Glue
B.Welwood's Avatar
I did my glider wing with LED strips. I carved out trenches with a utility knife to mount the strips under the wing profile. Then the wing was covered with laminate film to bridge the gap. Following that, opaque covering material to finish the surface.
Here is the finished wing....
Sep 20, 2019, 02:58 AM
Ok looks good, bet that shows up great! Any night pics?
So it seems it can be done.. without much fuse...
Discussion Has anyone done a comparison on these 3 coating ? Deluxe Materials Foam Armour, Bea 400fe Electric Plane Talk 0 Apr 22, 2018 05:34 PM
Discussion has anyone used waterproof LED strips remvideo Multirotor Drone Electronics 1 Feb 26, 2015 12:19 AM
Discussion How to wire up LED light strips into my Futaba Receiver flywmoi Night Flying 7 Mar 07, 2011 07:56 AM
Discussion LED Strips (Like UH LED Strips) Dim with Throttle Bohh33 Night Flying 13 Aug 22, 2010 11:07 PM
Question Sanding airfoils into sheet balsa stabs? Or, foam core tail surface? Sled Driver Slope 11 Nov 25, 2005 08:14 PM
