Sep 10, 2019, 10:30 PM
New Product
Looking for reviewers // Racerstar & Airbot airF7 F722 FC
Hi,Can anyone review this product?
If you guys have any review experience, feel free to leave your own channel in the comments section.
https://www.banggood.com/Racerstar-A...p-1547585.html
Sep 11, 2019, 12:53 AM
Sumfear's Avatar
Itīs a good toy. I like the extra features it has specially for the fpv area.
Sep 11, 2019, 02:01 AM
Interesting! Airbot is very reputable brand. I really like this cooperation.
I assume • 9V 3A BEC and • BT module will be available for purchase separately as add-ons and not included in the package? Or will it be an option to purchase with BT in the future?
What ICM gyro is used? There are none pictured in the photos.
Can BT module be powered off when quad is armed?
I would like to put my hands on this FC. Ready to for review.
Sep 11, 2019, 02:47 AM
FPV addict
mlilasic's Avatar
Interested in reviewing it. I did many racerstar products reviews, you can search for "racerstar" in my reviews bank:
https://www.rcgroups.com/forums/show...y-Reviews-Bank
Sep 13, 2019, 08:42 AM
alex_nikiforov's Avatar
In the photo I see a barometer that is not in the description
As a result of the cooperation of the brands, an interesting flight controller was obtained.
Universal controller for FPV racing or long range flights with the ability to install a Crossfire receiver and BT module
I can help if you need a review. You can find examples of reviews on the my blog.
Sep 18, 2019, 08:00 AM
Quad Erat Demonstrandum
scousethief's Avatar
Interested.
When someone creates a servo adapter board so that servos can be easily connected to the motor outputs you will sell a LOT more flight controllers to the plane community.
The biggest pita is.... as board size has been reduced and motor signal output is reduced to a socket anyone wishing to use a FC in a plane has to choose carefully or learn to solder ( and mod their sometimes expensive servos to solder direct )
I have done many of these modifications on everything from Eachine Brushed quadcopter boards ( converted to 3 servo + brushless motor) to Diatone and PikoBLX+OSD 20x20mm boards so i will be happy to review this and convert it for use in a plane.
Sep 29, 2019, 05:58 PM
angelo.p's Avatar
Received and mounted mine on my test quad.
Let's make a first list of pros and cons
PROS
- a lot of UART
- Double BEC
- the possibility to activate and deactivate the BEC for video transmitter is very cool feature. So you can power of your video transmitter when you need to power on the quad!
CONS
- lack of documentation. I guessed that mode user1 is used to activate the BEC. But I don't know how to use other modes for example.
- I don't have the connector diagram. So I don't know how to use the JST cable
Anyway in a couple of hours I replaced my old FC on my test quad and I made some test flight.
With stock PID my quad flyes well! Now I need only some little tuning.
I will post my video very soon.
Sep 30, 2019, 01:09 AM
Is there a barometer on board?
Sep 30, 2019, 02:20 AM
angelo.p's Avatar
Yes
Inviato dal mio Redmi Note 5 utilizzando Tapatalk
Sep 30, 2019, 06:03 PM
angelo.p's Avatar
My test video.
Racerstar & Airbot airF7 Flight Controller - Recensione e test (13 min 23 sec)
Oct 09, 2019, 07:18 AM
I recently bought 4x RacerStar 2514..
I can review the F7 FC together with motors...
Oct 11, 2019, 10:49 AM
Oh wow that is great speck! I'm an abbot fan, have had like 5 ESC 4-in-1 esc from them and a few FC. But this is so much better than F7 from Airbot on paper!
- true 3 amp is Very good for those who use vTX. like 600mw or more and split cam! makes it clean to set up
- and Baro is a must in my opinion, takes almost no space any way
BUT, ICM gyro?? BF already proved that higher rate give no advantage. 8/8k and dshot 600 is highest you can get now, and no reason to go higher. wish it was MPU6000
Oct 21, 2019, 02:06 AM
Has anyone heared of or knows more about: "Airbot Configuration assistant supported, easier to config the functions for the FC".
Google returns zero info except the Racerstar AirF7 product page. This is mentioned in the description.
Help! Matek F722 FC Component Identification ryanschwartz Multirotor Drone Electronics 3 Mar 07, 2019 10:39 PM
Discussion Airbot Omnibus F4 - V5 FC josephr Tricopter Drones 6 Aug 16, 2018 01:36 AM
Help! Matek F722-STD FC | Heavy pitch twitches Chris.Z Multirotor Drone Electronics 12 Aug 14, 2018 09:35 PM
New Product $22 F4 FC with VBAT/Buzz (Airbot F4 clone) & $24 F4 SPI/MPU6000 FC V1.2 lmpuIse Multirotor Drone Electronics 21 May 13, 2017 08:56 AM
New Product Racerstar RS20x4 20A ESC with Realacc HUBOSD ECO X Type 5V 12V PDB 6DOF F3 FC reviewdroneworld Multirotor Drone Electronics 0 Sep 23, 2016 07:02 AM
