Sep 17, 2019, 12:01 PM
1985 XL600R RFVC
smallengines1284's Avatar
heres a basic design for it
Sep 17, 2019, 02:20 PM
1985 XL600R RFVC
Finch - version 2
Hi everyone, Here are a couple pictures of the new version. I think the styling came out okay.
Sep 18, 2019, 12:23 AM
1985 XL600R RFVC
I got another micro design on the way, a brushless, canard, pusher jet using the RX brick from the a U.M.X Timber BNF, I'll be using a prop from a UMX Stryker for sure though for MAXIMUM SPEEEED
Sep 18, 2019, 05:06 AM
I hope to get mine in the air in the next couple of days, I got distracted at NEAT and didnít do any building.
-Fritz
Sep 18, 2019, 02:54 PM
1985 XL600R RFVC
Another plane in the works.
Hi Fritz, sounds good I'm excited to see how your brushless one does. I'm about to go put some more flights on my canard jet. I'll post a picture of it with this response. I'm using the umx Timber propeller right now so it's not super fast but it makes a lot of static thrust. I need to order a umx f-27 prop for it soon.
(The pitch is controlled ONLY by the canards, and the two elevon looking surfaces are for aileron only. I'll have to get a video of how it's set up soon as well. )
Sep 18, 2019, 08:57 PM
1985 XL600R RFVC
(deleted picture)
Sep 20, 2019, 02:36 PM
1985 XL600R RFVC
different color scheme
Sep 20, 2019, 09:53 PM
1985 XL600R RFVC
Finch version 3 - "Bluejay"
This is the Finch version 3 in the Bluejay color scheme. I put so many flights on the same motors that one of them is starting to make some bad noises at ~30% throttle. I'm using the same 2 micro quadcopter motors from when I first started the Finch project a few days or a week ago. I must have at least 30 flights on all the different versions combined by now. The version 3 update is bigger winglets for increased stability, the version 2 had a tendency to start yawing left to right when I would go full right aileron to full left a few times it a row quickly. Tomorrow I'll get some flights on the version 3 I just built, the yaw instability should be fixed with the bigger winglets.
If you are reading this wondering if it would be a good build then I am happy to report that of all the rc aircraft builds I've ever done with foam this tiny little wing is the fastest easiest best flying of them. it can be built in under an hour from the time you print the plans to the time it's ready for the first pre-flight C.G check. I'm very happy overall with the success of this design even though flying wings have been around a long long time I personally have never made any of my designs fly this good and be this reliably well flying.
Thank you for reading this article, I'll get back to you all tomorrow about how version 3 does in the air.
Update: It used to fly pretty good... got it stuck on my roof though.. This version is definitely the one to build if you're thinking of building one, the big winglets make it far more stable and I'm very pleased with its flight performance. I can almost squeeze 5 minutes out of it when its at 100% throttle the whole flight, too!
Sep 22, 2019, 07:38 PM
As a quick sidebar, the taileron version I posted was a flop. Not sure if the COG was horribly wrong or too much vertical area on the tail.
Sep 23, 2019, 06:41 PM
1985 XL600R RFVC
To be honest I think the whole design was just bad in general. I only had 1 airframe and it barely flew with a brushed motor too.
Discussion Wing Derringer large parkflyer scratchbuild MustangAce17 Scale Kit/Scratch Built 8 May 12, 2019 05:32 PM
Build Log T-70 X-Wing, Y-Wing, A-Wing and other Star Wars Builds (all with plans!) AJWoods Scratchbuilt Indoor and Micro Models 200 Dec 08, 2018 11:41 PM
Discussion Looking For Plans: Single Motor Seaplane Parkflyer Posted Years Ago Derek_S Foamies (Scratchbuilt) 3 May 06, 2017 06:01 PM
Discussion Vintage rc plan Beech 17 Stagger wing plans?? KOMET 44 Scale Fuel Planes 6 Jun 05, 2016 08:52 PM
Building parkflyers from plans: How to transfer plans to wood? War Bird Radio Parkflyers 13 Jun 20, 2003 09:58 PM
