This thread is privately moderated by GroundControlRC, who may elect to delete unwanted replies.
Sep 10, 2019, 02:58 PM
Video
Needful Things - Low Profile Lock Nuts / Prop Nuts
Here is a link to the Video:
https://www.youtube.com/watch?v=TDLwhqvQCWQ
I was installing the RacerStar SIC 2207 2688kv Motor in my "Glue & Fly" Series F-22 Mini V3 using the Prop Nut that came with the Motor and realized it wasn't going to work.
This Motor does not have a long enough shaft to use a 6x4 Prop with the Stock Prop Nut.
There was not enough of the Shaft beyond the 6x4 prop to allow the Stock Prop Nut to thread all the way down and so the Nylon Thread Lock was useless.
Luckily I had some Low Profile Lock Nuts / Prop Nuts on hand and that saved the day ;-)
Could you imagine not being able to perform Test Flights of a new Motor because the Stock Prop Nut wouldn't work with the Prop you're using?
I certainly don't want to have to wait for Low Profile Prop Nuts to arrive, that would take days or weeks!
Make sure you have some CW & CCW Low Profile Prop Nuts in your kit or supplies as you WILL eventually need them.
You Can Help Support Us By Using Our Affiliate Link To The Product Below. A small commission (At No Cost To You) helps us buy more items to review.
Here are links to some Low Profile Lock Nuts / Prop Nuts:
5 PCS Gofly-RC M5 Aluminum Motor Screw Nuts Nylon Insert Self Lock CW/CCW for RC FPV Racing Drone - Red CW
https://www.banggood.com/5-PCS-Gofly...47791920140372
Aluminum Flange Low Profile Nyloc Nut M5 (4 Black CW & 4 Silver CCW)
https://hobbyking.com/en_us/m5-alu-s...asc=5096350201
Aluminum Flange Low Profile Nyloc Nut M5 Silver (CW) 8pcs
https://hobbyking.com/en_us/m5-alu-s...asc=1358858863
Aluminum Flange Low Profile Nyloc Nut M5 Black (CCW) 8pcs
https://hobbyking.com/en_us/m5-alu-b..._asc=935174868
See you in the Air!
Consider Supporting Our Channel by becoming a Patron at: https://www.patreon.com/groundcontrolrc
Patrons of the Channel will have Exclusive access to Aircraft Plans & Content!
See Us On Youtube | Patreon | RCGroups
Discussion Proper method to tightening prop lock nuts? MarkDeLo Multirotor Drone Electronics 7 Dec 12, 2016 01:31 PM
Discussion Low Profile lock nuts on DYS 1806-2300kv Motors MicroFantastik Beginner Multirotor Drones 7 Dec 06, 2015 03:56 PM
Question Low profile losi left and right hand threaded lock nots, 5mm exnihilo Scratchbuilt Multirotor Drones 2 Jul 18, 2015 11:12 AM
News JConcepts TLR 22 front axle conversion and low-profile locking wheel nuts Paul Onorato Car Talk 0 Oct 04, 2013 04:03 PM
Prop Lock prop nut XTheOwl Fuel Plane Talk 1 Jun 07, 2004 08:31 PM
