This thread is privately moderated by Blaze0021, who may elect to delete unwanted replies.
Sep 10, 2019, 10:47 AM
Blaze0021's Avatar
Video
Durafly EFXtra 975mm Racer - Video Capture Challenge 4S Flight
In 1080p 60fps - This is a Video Capture Challenge Flight of my Durafly EFXtra 975mm Racer.
Durafly EFXtra 975mm Racer - Video Capture Challenge 4S Flight (5 min 26 sec)
My friend Brad had been looking forward to the challenge of capturing my old Durafly EFXtra "Bolt" on video this past weekend. He's been taking excellent footage of my EDF jets, but the EFXtra is a completely different animal to capture well (if at all) on video. This is also his first experience seeing an EFXtra up close in action.
Will Brad manage to keep his video target locked? Stay tuned!
TRANSMITTER, RECEIVER, & SETUP
Transmitter: Spektrum DX8 G2
Receiver: Lemon RX DSMX 7-Channel Diversity Stabilizer / Receiver "LM0033"
Stabilizer Gains: 9 O’Clock Setting on all Axis-es
Master Gain: +0
Rates Used: 100%-Aileron / 40% Expo, 100%-Elevator / 25% Expo, 100-Rudder, 0% Expo
Propeller: Stock 7x6.5 2-Blade
Additional Modifications: Minwax Satin Finish Polycrylic Protective Coating (2 Coats)
Battery: Pulse 4S 2250mAh 45C (241 grams)
Battery Positioning: Full Forward
Throttle Timer: 4 Minutes
Total Flight Time: 4 Minutes, 18 Seconds
Lipo Final Voltage: 15.22 Volts out of 16.80 Volts (~3.81 / Cell) at 34%
ADDITIONAL INFO
Camera: iPhone 6 at 1080P / 60 FPS
Cameraman: Brad L.
Music: "Siren's Song" - Ace Combat 7 Original Soundtrack
Thanks for watching!
Sep 11, 2019, 02:08 AM
eagle60's Avatar
Suggest you edit the video sound cutting frequencies below 1300-1500 Hz to reduce wind noise
Sep 11, 2019, 07:56 AM
Blaze0021's Avatar
Thanks for the suggestion I thought about doing that, but then you’ll get the other skeptics that will say that it wasn’t really that windy.
Sep 11, 2019, 09:07 AM
eagle60's Avatar
then you can do it on 70 % of the video explaining what you made to reduce environment noise.
Sep 11, 2019, 09:56 AM
Blaze0021's Avatar
Not a bad idea. The other issue that I came across is being able to keep the sound of the “EFXtra whoosh” while reducing the wind sound.
I’m working off of iMovie in my Mac Air. I know there’s other editing software that allows to split sound waves so I can reduce things like for example an annoying talker on the field that can’t keep his mouth shut, lololol. But that software is quite pricey. iMovie is free.
Hate the wind noise. But love that whoosh.
Sep 12, 2019, 05:05 AM
eagle60's Avatar
try with the equalizer : motor noise is well above 1300-1500 Hz and wind noise is 70-80% below that frequency. I did use Sony sound forge 9 (that I got free) that allow to edit also sound of videos. And you can do it on any part of it at your choice
Sep 14, 2019, 01:23 AM
Blaze0021's Avatar
Thanks man. I think I figured out a way to reduce the particular wind noises when using iMovie. It definitely helps cut down the abrasiveness of the wind. Thanks for the tip!
Review Durafly EFXtra Racer/FPV Review Jason Cole Electric Plane Talk 349 Feb 13, 2019 05:30 PM
