Sep 10, 2019, 12:15 AM
Build Log
J3 cub 1180mm
My J3 Cub 1180mm balsa build log.
I purchased this kit from Banggood, quality seems good, nicely cut parts, poor instructions however.
Sep 10, 2019, 06:00 AM
'Douglas' to his friends.
Looks like you're off to a good start. Keep 'em coming, and thanks for sharing.
Sep 10, 2019, 11:24 PM
Thank you, its my first model so steep learning curve made even more challenging as the instructions leave you guessing a lot of the time!
Sep 12, 2019, 12:10 AM
Update
Sep 12, 2019, 12:48 PM
Joker 53150's Avatar
Nice progress! I've done a few of the cheap Chinese kits before and their instructions are certainly.... "interesting". Tiny pictures, horrible translations, misinformation, and incorrect data. Other than that, they're great! I've always felt that if you can build a Chinese kit you can build just about anything.
Sep 12, 2019, 11:35 PM
Yes they are not the best but very cheap! I started the wings last night and they are extremely hard to build following the single low res picture!
Sep 13, 2019, 12:17 AM
N = R* fp ne fl fi f
Azoic's Avatar
I see what you mean about poor instructions. I looked for an 1180mm span Cub, but the nearest I found was the 1200mm. It's manual shows a few assembly shots and a lot of Chinese. It's not too hard, and there is lot's of help to be found here on RCG. If you can't find how something fits, just ask, someone will help.
The Dancing Wings 1800mm Cub, also sold by Banggood, has even less in it's manual. The link for both of these is below. I also attached a copy of the wing pictures in the 1200mm manual. Both manuals can be found via the links below.
https://www.banggood.com/Pipe-J3-Cub...r_warehouse=CN
https://www.banggood.com/Dancing-Win...r_warehouse=CN
Sep 13, 2019, 12:26 AM
Hi, thankyou, yes I found a few people with the same issues on here and managed to work it out. For anyone else about to build this kit be aware there are 3 types of wing spar in the kit. The thinner spars are for where the top balsa boards go on the wing.
Sep 13, 2019, 03:44 PM
More work on the wings and changed the standard foam wheels for larger rubber ones.
Sep 13, 2019, 11:48 PM
Azoic's Avatar
It's looking good, I think the cheap foam wheels would be fine, and lighter. They look quite cheap, I admit, and the rubber ones are closer in shape to scale, add some Cub hubcaps and your set. Cut the bottom out of 2 mini soda cans, cut to the right size, and paint them to suit the finished scheme. They will make ANY wheels look a lot better, just glue with a few dabs of hotglue onto the wheeel hub , then if needed they can be prised off with a screwdriver if you need to fix or change a wheel.
Sep 15, 2019, 11:39 PM
I think the rubber wheels look loads better, might try and do your hubcap suggestion.
Some more progress over the weekend.
Sep 29, 2019, 11:35 PM
Update
Sep 29, 2019, 11:36 PM
Wrapping with monokote for the first time.
Build Log HK laser cut kit cub 1180mm build Stuart Linfoot Scale Kit/Scratch Built 440 Sep 23, 2019 09:35 PM
Discussion hk/ele laser cut kit cub 1180mm slowbuild ghostwhiper 1/2A Planes 11 May 20, 2019 04:49 AM
Discussion J3 Cub 1180mm Neovivacity Scale Kit/Scratch Built 3 Feb 10, 2018 04:41 PM
Discussion Parkzone Sport Cub Vs. FMS J3 Piper Cub RcMetal Electric Plane Talk 8 Apr 07, 2016 05:46 PM
Question Hangar 9 J3 Cub 1/4 Scale Electric Motor TX79 Glow to Electric Conversions 1 Oct 25, 2015 07:21 AM
