VD16-E 16-Channel Radio Controller - Foxtech
VD16-E is a highly integrated radio system which has datalink, videolink and rc built inside with standard range up to 3km on the ground and 5km in the air.
VD16-E
The VD16-E supports ethernet port video transmission, so connect EH314 4k camera with the VD16-E receive for real-time video transmission. Connect the remote controller end to the PC and the video can be directly displayed on PC. Connect the mobile phone and remote controller with a USB cable and you can also see the video from your mobile phone. You just need to download the software on your phone. It is very convenient. Connect the VD16-E receiver and ethernet version gimbal with an sbus module for camera and gimbal control - like camera zoom, REC, PIC, gimbal pitch/yaw, etc.
The VD16-E has the Bluetooth function can send the data to your cellphone. So you can see all parameters or settings on your cellphone. It also has a bright and colorful LCD touch screen. The VD16-E Radio controller has a built-in lipo-battery, it can be connected through a USB cable for charging, and the endurance time is about 10 hours.
Specifications:
  • RC/Data Transmission Distance: 10km
  • Video Transmission Distance: 3km
  • Working Frequency: 2.4 GHz
  • Channel: 16 Channel
  • Bluetooth Pairing Password: 1234
  • Admin Password: 8888
Controller:
  • Video Output Interface: USB, Ethernet Port
  • Datalink Port(connect mobile phone, PC): Bluetooth, Micro USB
  • Size: 194.5x172.5x114mm
  • Weight: 942g
  • Battery: 15000 mAh Lipo 1S 3.7V
  • Charging: Micro USB 5V 2A
Receiver:
  • Signal Output: 16-channel S.Bus, 9-channel PPM/PWM
  • FC Connecting Port: UART
  • Size: 61x60x21mm
  • Weight: 82g
  • Antenna Gain: 5dBi
  • Working Voltage: 15V-50V
  • Working Temperature: -10℃-55℃
[img][/img]
Camera with Searchlight:
  • Video Resolution: Max. [email protected]
  • Camera angle: FOV 150
  • Searchlight Power: 8W
  • Size: 106x25x41mm
  • Weight: 108g
  • Luminous flux: 1W/120-140lm
  • LED Searching Angle: 120
Your Purchase Includes:
  • 1x Foxtech VD16-E 16-Channel Radio Controller
  • 1x VD16-E Receiver
  • 1x Camera with Searchlight
  • 1x Receiver Antenna
  • 1x UART Cable
  • 1x Ethernet Cable
  • 1x USB Cable
  • 1x 2.4G Feeder
  • 1x 5.8G Feeder
[[mg]https://www.rcgroups.com/forums/showatt.php?attachmentid=12531915[/img]
Learn More!
Head to Foxtech for pricing and more!
News Graupner - MZ-16 16-CHANNEL 2.4 GHZ TELEMETRY RADIO Jim T. Graham Radios 74 Jul 31, 2020 01:36 AM
New Product Graupner mz-16 - 16-channel radio Graupner USA Radios 2 Jan 30, 2019 05:37 PM
New Product YD717 4-Channel 2.4GHz Radio Control 6-Axis R/C UFO Kenxiaofei Multirotor Drone Talk 1 Oct 11, 2015 09:56 AM
Link YD717 4-Channel 2.4GHz Radio Control 6-Axis R/C UFO Kenxiaofei Multirotor Drone Talk 1 Sep 13, 2015 09:42 AM
