Oct 25, 2020, 02:13 PM
Classic jets rule
AIR SALLY's Avatar
It is just hanging ,when flying it get pushed back . I may spring load it a bit to keep it clear.
Oct 25, 2020, 04:20 PM
Classic jets rule
AIR SALLY's Avatar
I also added solid C/F rod to the main C/F spar so that the wing hold clamps wont damage the spar.
Oct 25, 2020, 07:13 PM
EDF all the way!
bruff's Avatar
Moving along.
Here are some more pictures of my Draken. Wings are glue in place. Servos, retracts, Byron fan w/Talon 120 ESC install. Wings are being glassed with fuselage. Next install outbd control surfaces and tie them to inbd control surface.
Bob
Oct 25, 2020, 11:29 PM
Foam abuser!
crxmanpat's Avatar
Looking good Bob!
Pat
Oct 25, 2020, 11:38 PM
Still Screamin'!
rvincent's Avatar
We gonna have a Draken squadron here soon. Let us know when the maidens are!! I wont see Rodger's but I can see Bob's and Pat's
Oct 26, 2020, 10:47 AM
Classic jets rule
AIR SALLY's Avatar
Look really nice Bob.
I put the 65 mm tires on mine and i had another style JP nose strut with a shorter "blue" spring so i swapped out the "yellow " spring, ill post a pic later of the stance, but should reduce the AoA of the nose and raise the aft end up a bit.
Pat we have to move the nose gear mount up to lower the nose a bit. Where is yours sitting?
Oct 26, 2020, 02:51 PM
Classic jets rule
AIR SALLY's Avatar
Madien flight date???
So looking ahead to a madien date that works for the Test pilot, project manager, manufacturer, power plant specialist, and friends
I feel it best to use a lake bed for the madien,and i think Justin's rabbit dry lake is a good choice as it closer to project manager Pat. A longer drive for Test pilot Brent,and manufacturer Me.
I need to do this on Saturday the 7th or 14th if that works for all involved. Weather in lucerne valley would be 76* with 8mph winds out of the WNW.
Justin if you could keep an eye out on the weather and and lakebed conditions and traffic out there. Is the gun range active? Ect.
Let me know what you think Pat,Brent,Gary(Efflux RC power plant specialist) Justin, and anybody else that would like to come.
I have a few things to button up,and hope Brent has time to tune the ESC.
Let me know what you guys think.
Oct 26, 2020, 02:59 PM
efflux RC's Avatar
Rodger
I was thinking I'd like to try to get out there for the maiden. Thanks for the heads up. Keep us posted on the date.
Latest blog entry: Updated blog - Oct 2017
Oct 26, 2020, 04:12 PM
Foam abuser!
crxmanpat's Avatar
Rodger,
11/7 works better for me than 11/14, but only because we have our club/board meetings on the 14th. But if it winds up being the 14th, I can skip the meetings.
I'll drive over Friday after work and stay at a hotel in Apple Valley, then meet up with you guys at the lakebed Saturday morning.
Pat
Oct 26, 2020, 04:33 PM
JLink125's Avatar
Either date should work fine for me Roger. I'll watch the weather and related conditions for you and give reports as we get closer. Early morning is always best, as for the gun range its not on the lakebed at all so no concerns there. I do believe its active so you will likely hear them off in the distance but thats it.
Oct 26, 2020, 04:35 PM
Foam abuser!
crxmanpat's Avatar
Better than Whittier Narrows I'm sure.
Pat
Oct 26, 2020, 04:40 PM
Dont forget the velcro straps
corsair nut's Avatar
7th should work for me. 14th would probably be ok too. but 7th slightly better
think you could fit the 70mm tires dad?
Battery Puffer
I should have my T1 ready by then. Maybe I will make it too.
Oct 26, 2020, 04:47 PM
Classic jets rule
AIR SALLY's Avatar
70mm tires wont fit. I had to sand some of the opening for the 65mm to fit. Id have to move the retract units inboard . Also not sure 70mm tires would fit with the wheels that fit 60 & 65mm tires
Mark yeah please come if your ready. We can make a mini event out of it.
Oct 26, 2020, 05:14 PM
efflux RC's Avatar
The 70mm tires will not fit the 65mm size rims. The 70mm Brakewheel design will require a whole different strut mounting method. They are not the same design as the 45 thru 65mm sizes.
Discussion Saab J35 Draken Lockey Foamies (Scratchbuilt) 137 Oct 21, 2020 06:50 AM
Question Any SAAB J-35 Draken profile kits still made ? cyclops2 Foamies (Scratchbuilt) 3 Aug 25, 2019 09:02 PM
Discussion Saab 35 Draken Shattered Dreams Pusher Prop Jet Models 0 Nov 27, 2016 11:37 AM
Saab J35 Draken building thread Brauer Electric Ducted Fan Jet Talk 38 May 17, 2005 10:58 AM
