Dec 05, 2019, 08:16 PM
Foam abuser!
crxmanpat's Avatar
I just tried it. Secured the clamp with some 6/32 socket-head bolts and there is still enough "give" in the clamp to tighten around the rod.
Pat
Dec 05, 2019, 08:54 PM
Classic jets rule
AIR SALLY's Avatar
Originally Posted by crxmanpat
Yeah, they cater mostly to the robotics crowd, but lots of stuff there that we use as well. I purchased my servos from them as they specifically had anodized aluminum arms for the servos as that's what I need for the F-22. I want absolutely no slop in my control linkages.
Pat
Nice find Pat ...those look very much up to the task.
Dec 05, 2019, 09:08 PM
Foam abuser!
crxmanpat's Avatar
They seem like it Rodger. All they really need to do is keep the spar from sliding out. The spar and alignment rod will already pass through two formers on the inside of the fuse, so they will be secure.
Here's how it all fits together.
Pat
Dec 05, 2019, 09:12 PM
EDF all the way!
bruff's Avatar
Looking good1
bob
Dec 05, 2019, 11:17 PM
Classic jets rule
AIR SALLY's Avatar
Were those parts included in the cut files you sent me?
Dec 05, 2019, 11:57 PM
Foam abuser!
crxmanpat's Avatar
Most of those are only partials of bulkheads 4 through 8, that's why they look weird. I only had a small sheet of ply for the sample cut, so I was not able to get the full bulkheads cut out.
Pat
Dec 06, 2019, 12:30 AM
Classic jets rule
AIR SALLY's Avatar
I could tell the bulkheads were partials. But are the pieces that the spar is supported with included?
Dec 06, 2019, 08:35 AM
Foam abuser!
crxmanpat's Avatar
Yes. They are in the file called Draken Wing Formers.
Pat
Dec 07, 2019, 07:10 PM
Classic jets rule
AIR SALLY's Avatar
So today Brent helped me pull a couple of canopies for test fitting, now i need to make a mold that will make up a fiberglass piece that we can cut out any canopy frame to add detail.
Dec 07, 2019, 10:34 PM
Foam abuser!
crxmanpat's Avatar
Very nice!
Pat
Dec 13, 2019, 10:50 AM
Foam abuser!
crxmanpat's Avatar
Rodger,
Any word back yet from your laser cutter? I can get the files cut here if necessary, I'd just have to get some 1/8 birch stock.
Pat
Dec 13, 2019, 08:06 PM
Classic jets rule
AIR SALLY's Avatar
Hes on it ,i should know more tomorrow.
I started cutting glass for your fuse. Trying to get organized to start some production.
Dec 14, 2019, 12:40 AM
Foam abuser!
crxmanpat's Avatar
Nice! Can't wait to get one of these going.
Pat
Dec 14, 2019, 02:32 PM
EDF all the way!
bruff's Avatar
Looking forward to it. Have the Byron power system, retracts, and radio. Waiting on airframe to build.
Bob
Dec 14, 2019, 04:01 PM
Classic jets rule
AIR SALLY's Avatar
Test pieces are cut, ill pick them up tomorrow.
Question Any SAAB J-35 Draken profile kits still made ? cyclops2 Foamies (Scratchbuilt) 3 Aug 25, 2019 09:02 PM
Discussion Saab J35 Draken Lockey Foamies (Scratchbuilt) 126 Nov 05, 2018 01:27 PM
Discussion Saab 35 Draken Shattered Dreams Pusher Prop Jet Models 0 Nov 27, 2016 11:37 AM
Saab J35 Draken building thread Brauer Electric Ducted Fan Jet Talk 38 May 17, 2005 10:58 AM
