This thread is privately moderated by old_dude, who may elect to delete unwanted replies.
Sep 08, 2019, 04:21 PM
Trader Rating: 396
Groundloop World Champion
old_dude's Avatar
$18.00 USD
Buyer pays shipping
For Sale
Dual Strut Nose Gear, New .... Three
Three new dual strut nose wheel landing gear each with mounting bracket and double sided control arm. The control arms may be mounted above or below the mounting bracket. The struts are 3.0mm in diameter. These are for .40 size aircraft. These are not Fults. They are strong ! ! The mounting bracket is 1" high x 1-1/2" wide. Mounting holes will accommodate 4-40 screws. These are not Fults.
The struts are approximately 3-3/4" from the bottom of the spring coil to the 3.5mm diameter axel. That length can be shortened to level the ground attitude of the model. A maximum 7/8" wide wheel can be used.
The unit on the left is not assembled for two reasons.
First to show the various parts. The second reason is one of the axel mounting sleeves does not have the hole drilled in it as shown in the other photo. I no longer have a V block or drill press to bore the hole. So that unit will be reduced by $5 if you want it.
The mounting sleeves are slotted so that wheel collars with set screws can be used to attach them to the struts as shown in the first photo. Wheel collars are not included. The one shown is a 3/16" collar and slides snugly on to the sleeve. The sleeves can be silver soldered on the struts as an alternative to the wheel collars. A maximum 7/8" wide wheel can be used.That would nominally dictate a 2-1/2" diameter wheel.
$20 each + $3.50 shipping for 1 or 2 via USPS First Class
$15 for the one that needs a hole drilled + $3.50 shipping for 1 or 2 via USPS First Class
Paypal payment
Ready for questions and thanks for looking
Old_dude
Sep 13, 2019, 09:23 PM
Trader Rating: 396
old_dude's Avatar
Updated details
Sep 20, 2019, 11:06 PM
Trader Rating: 396
old_dude's Avatar
Weekend bump and then will fade away
Sold Dual strut nose gear nh4clo4 Aircraft - General - Miscellaneous (FS/W) 2 May 25, 2016 01:14 PM
Sold Fultz RF500 dual strut nose gear new in package !!! hobbyfun100 Aircraft - General - Miscellaneous (FS/W) 2 Apr 19, 2016 03:40 PM
Sold Fultz Dual Strut Nose Gear's !! hobbyfun100 Aircraft - General - Miscellaneous (FS/W) 4 Mar 22, 2016 08:18 PM
Sold Fultz Dual Strut Nose Gears hobbyfun100 Aircraft - General - Miscellaneous (FS/W) 2 Feb 29, 2016 06:40 PM
Sold Fults Dual Strut Nose Gear - Model RF350 .40-.60 nero1156 Aircraft - General - Miscellaneous (FS/W) 1 Feb 07, 2016 12:28 PM
