Sep 07, 2019, 10:55 AM
Occasionally here
regis's Avatar
Question
CellPro Multi4
I purchased this charger from FMA (July sale). I had to wait to get the charge board adapter. I finally turned it on last night - with great expectations… Well not so great! The display said, “Supply >16 Volts Push to Reset”. Yes the manual says use only 10 to 16 volts. I checked the listed output on my transformer and it said 14.5 volts. I then measured actual output with a volt meter and it was showed 14.2 Volts. I then checked a few batteries to see if my Volt meter could be off. No, volt meter was accurate. Of course this happened on a Friday night and I can’t reach FMA until Monday. And tomorrows weather forecast is great. So the question is: Is this an anomaly? Did I just get a bad item? Regis
Sep 08, 2019, 07:17 PM
Try connecting it to your 12v car battery w/o the car running.
Question Cellpro Multi4 Not Accurately Detecting Number of Cells? andygua Batteries and Chargers 14 Dec 25, 2017 02:33 AM
Discussion LIPO Charge Rate on a CellPro Multi4 JohnMyers Batteries and Chargers 5 Jul 09, 2016 07:20 AM
Help! Where in EU get pigtail for cellpro multi4s? miodzicho Batteries and Chargers 1 Jun 21, 2016 06:55 PM
Discussion Cellpro Multi4 Parallel Charging... sloperb Batteries and Chargers 2 Jan 01, 2016 12:12 AM
Discussion Cellpro Multi4 deswong Batteries and Chargers 1 Oct 16, 2008 06:33 AM
