Sep 05, 2019, 09:10 PM
777
777
Bought at a price.
4s in a thin wing?
I've been away from the hobby for a bit, but I want to return.
I have a 36" Wing Warrior E-Zipper (remember those?) that I used to run 12 NiMH in. I want to switch to 4s, but it seems as though 4s packs are quite thick. The E-Zipper is very thin. I'm not sure how to fit a 4s in there.
How would you fit a 4s in a thin wing? What pack (size, brand) would you suggest?
Thank you,
Brad
Sep 05, 2019, 09:25 PM
Maybe 2 2s pack in series if you need it thin.
Sep 06, 2019, 08:22 PM
Honorable Deplorable
Why not get a typical 4s pack, remove the outer jacket and separate two cells, then reseal? As long as you know what you are doing...you should be ok
Sep 06, 2019, 10:55 PM
pull up -- PULL UP!!!
This one is similar to what I run in a wing -- pretty thin @ 21mm for it's capacity. They have another at 19mm but only 1500mah.
http://www.valuehobby.com/power-syst...800mah-4s.html
Sep 06, 2019, 11:32 PM
If it flies, I can crash it.
rocketsled666's Avatar
LiPos come in all shapes and sizes, and there's no rule that says you have to use a single monolithic pack. Short/fat, long/thin, rectangular.... I've got 4S packs that are the normal "brick" shape, and I've got 4S packs that are shaped more like a paperback book, and I've got 4S packs that are almost a cube. You have to figure out how much space you have and how many mAh you need, and shop around for a solution. But I'd be surprised if you couldn't find a solution.
Sep 07, 2019, 10:36 AM
If necessary for a particular application it wouldn't bother me to install two 2S batteries with a series adapter. But probably need to select only from high-C batteries in order to get heavy enough primary wiring.
Discussion Servos for Thin Wings? ForeverFlying Radios 8 Sep 30, 2015 11:12 PM
Discussion Thin wing servos ? mike912e Electric Sailplanes 27 Sep 19, 2015 07:21 PM
Discussion New servos, mounting in thin winged X-Plane GregG High Performance 20 Jul 16, 2012 08:46 AM
Discussion Forming Dihedral Breaks in Thin Foam Wings 356Jim Scratchbuilt Indoor and Micro Models 13 Oct 26, 2008 11:59 AM
Question HS-45HB for slope in thin wings? AndreasMergner Slope 33 Mar 10, 2008 05:25 PM
