Sep 10, 2019, 07:19 PM
Lot of water; some gets thin
chum444's Avatar
An update on vinegar. Experimented with heated vinegar & about an hour of immersion. After spraying adhesion seemed okay(not ready to say great) but to me much better than merely sanding brass rails. Long term durability yet to be determined. Causes me to think that sanding the brass and then using vinegar might be a reasonable low-cost solution with the added advantage of eliminating another can of paint in inventory.
Sep 11, 2019, 08:40 PM
20M northeast of Hell Mi
liljimmy's Avatar
I was in the process of soldering railings when I placed one in the wrong spot. I popped it out and rest of the railings started to come with it. I continued removing that “ run” of railings I repaired that rail then placed it in a hot vinegar bath just like you . To my surprise the flux came off ,it looked like it cleaned and prepped the brass. I let the part air dry hit it with spray bomb S.E.P. ( self etching primer) then white paint and reinstalled the railings as an assembly it worked out so I pulled the rest of the sections of rail and repeated steps above . No masking / over spray
Latest blog entry: Blog
Sep 12, 2019, 05:09 AM
Latitudes vs Attitudes
Bob Gaito's Avatar
Bill and liljimmy-right you are-I always a vinegar bath (use cleaning vinegar and not salad vinegar-its 5% acid,as stated above) and then a 000 steel wool shine...then paint
Latest blog entry: Mark V Navy Seal SOC
Sep 15, 2019, 09:11 PM
chum444's Avatar
Bob,
Added your steel wool technique to heated vinegar with a couple hours immersion. Not exactly finest kind but works pretty darned well. Well enough that I won’t be adding another 95% full rattle can to my inventory of cans.
Last tweek....what is cleaning vinegar?? Sounds like something that could not double for use in salad dressings.
Bill
Sep 16, 2019, 05:35 AM
Bob Gaito's Avatar
Bill, I just buy it in the stop and shop, its under $4/Gal(5%acid)..I did see that Home Depot sells 30% for $25/Gal-but I don't know about that strength and more over, I'm too cheap!
Discussion Photo etching for hobbyists? B_Honeydew Scale Boats 7 Jul 07, 2017 10:37 AM
Discussion How to make a nice aluminum etching at home or in a small workshop. Full guidance fro GF_Robots 3D Printing 0 Jul 19, 2016 04:12 AM
Discussion Mi primer vuelo y mi primer estampe cessna 182 pro parkflyers kenlider Mexico 2 Sep 28, 2009 06:14 PM
Discussion Mi primer planeador autoconstruido y mi primer vuelo fotos de su construccion y vuelo joypilot Mexico 18 Sep 29, 2008 10:53 AM
