Sep 03, 2019, 07:56 AM
Whirlygig Tricopters (2 and 3 inch)
STL Files https://www.thingiverse.com/thing:3639210
2" Video
2 inch Whirlygig Tricopter flight on very windy day (3 min 34 sec)
3" Video
3 inch Whilrygig flight on windy day 9 3 2019 (4 min 39 sec)
2" Hardware
BetaFPV F4 2-4S AIO (Betaflight 3.5.3)
Bluebird BMS-101HV Servo (19 tooth spline)
DYS BE1102-7800KV
Frsky XM+
2030 Props
2S 300mAh Lipo
FPV Micro AIO Camera 5.8 g 40CH 25 mW
Camera Holder https://www.thingiverse.com/thing:3726519
Zip-ties, < 2.5 mm wide & 1 mm thick
3" Hardware
Matek F405-Mini Flight Controller 20 x 20 (dRonin)
Aikon 4in1 ESC 35a 6S (20x20)
Mini 360 micro BEC (5v @ 3A, Flight controller)
Mini 360 micro BEC (7.5v @ 3A, Servo)
Emax RS1106-4500kv Motors
AVAN Mini 3" Props
Runcam Mini 2 with TX200U
Frsky R-XSR Receiver
Sep 03, 2019, 08:50 PM
Awesome Job!
Sep 27, 2019, 01:58 PM
What firmware you running on these?
Oct 22, 2019, 08:04 PM
I built one and it flies great.
Nov 21, 2019, 06:40 PM
Ciao,bellissimo il tricottero,vorrei costruirlo anche io,devo solo capire come cablare i motori il servo di coda alla fc f4 betaflight e come configurare il tutto.
Mi potete aiutare in questo progetto?
Nov 25, 2019, 02:53 PM
Vorrei iniziare con questo video:
TRICOPTER LR - Long Range FPV, 1h+ Flight time, Foldable multirotor - Build Video. (25 min 37 sec)
Buona Fortuna.
Jan 20, 2020, 10:58 AM
build guide please!
Jan 23, 2020, 06:22 PM
Here's my 3" version. Specs:
1)3D printed frame from PLA+
2)BE1102-7800KV motors with 3x2 props
3)BetaFPV F4 flight controller
4)BetaFlight 4.1.1 with custom config file and custom triflight 0.5
5)R-XSR receiver using Fport
6)350 mah 2s battery
7)I can't recall what the servo brand is, but it's a high voltage model
running directly off the 2s battery and modified for servo feedback
Only flown a few times so needs some more tuning work, but already it's
flying quite well.
Jan 24, 2020, 09:24 AM
Awesome! I love it! Are the design files available to print the frame?
I might print a regular quad frame first, but my goal is to build a small Tri.
Jan 24, 2020, 10:29 AM
Are we not men? We are DEVO!
xanuser's Avatar
Errr. Um....
Didya check the top of the OP?
Jan 24, 2020, 11:36 AM
oh sorry i didn't realize it was the same design, i thought the original was cut from carbon
Help! Tricopter Tail Servo Jitters, Multiwii Pro 2.3 board dynam Tricopter Drones 1 Mar 22, 2016 06:59 AM
Help! Tricopter Tail servo Jitters, Multiwii pro 2.3 board dynam Multirotor Drone Electronics 0 Mar 21, 2016 09:06 PM
