Sep 01, 2019, 08:53 PM
Help!
SAFE Select not working
I recently bought an ar636a for a plane I have and have bound it in SAFE Select mode and tried setting a switch to toggle it but have disabled SAFE completely and cannot get it working again. I have tried binding it in non SAFE then SAFE again but still no results. any help would be appreciated
Sep 02, 2019, 06:23 AM
Perpetual Noob
BoxCar31's Avatar
The 'a' versions of the AR636 are shipped with BNF planes. Did you buy the receiver from a 3rd party? Those models may not be programmable for use in another airframe but to be certain, you need to check it with the programmer and cable.
Sep 02, 2019, 01:45 PM
ICM
ICM
Assuming you bound correctly by powering up, letting the RX initialize and then removing the bind plug before binding, did you assign the switch to an OPEN channel on your TX (for example aux 1 or 2) making sure you have 100% travel before toggling? If not, you must do so or the switch won't work. Also, if you set up dual rates, make sure your rates are set at 100% when binding for Safe Select or Safe won't work.
Discussion Safe Select Will Not Turn On GaryP1936 Radios 9 Apr 20, 2019 04:02 PM
Help! mode select not works in FrOS for X12S ver. 1.5.03 lollobrigido FrSky 1 Feb 15, 2018 10:16 AM
Discussion E-Flite Apprentice SAFE Mode not working Calaski8123 Beginner Training Area (Aircraft-Electric) 11 Jun 03, 2017 07:48 AM
Discussion Fail safe not working, Naze 32 rev. 6 Full, Futaba 10C Fedko Multirotor Drone Electronics 2 Nov 17, 2016 05:15 AM
Discussion SAFE not working properly with DX6 master slave combo, trmcph01 Beginner Training Area (Aircraft-Electric) 3 Aug 22, 2016 12:24 PM
