Feb 24, 2005, 12:31 AM
Tough Engine Story
An old Magnum .25, full throttle in a dive from 50' hitting extremely hard packed ground. OHHH, the sound it made. The plane was easily in 500 pieces...servos exploded, fuel tank destroyed, prop only 3/4" long...you know what I mean. Anyway, that engine ran two days later like it was brand new without any new parts...just a complete teardown and cleaning, and I even had to solder the steel needle valve housing back together and straighten the needle which looked like the letter J
Feb 24, 2005, 01:52 AM
The reviewer
XJet's Avatar
I've got a Norvel 061 that was on a Littler Stick.
I had just dived from about 200 feet and pulled out level over a sealed tarmac runway when (for some strange reason) it did a snap roll straight into the black-stuff.
The plane was totally destroyed right back to the rear of the wing -- just confetti.
The prop was just a hub, the prop-mounting screw was bent real bad and the muffler was scraped -- but after replacing the prop bolt, it still runs sweet-as.
Not many engines survive and vertical smack into a real sealed runway -- it's a *lot* harder than even the hardest clay ground.
Cool TOP PICKS: One of the COOLEST things I saw while I was there. What's yours? philosophicle_1 Toledo Weak Signals RC Expo 2 Apr 20, 2007 01:50 PM
Discussion any one know what's that plane is szewang2805 Electric Plane Talk 11 Dec 26, 2006 07:51 AM
Alert What's inside that brand new engine. Allan Waterfall Motorcycles 12 Mar 03, 2006 06:54 AM
So, what's the ONE thing that's worse than crashing? tim hooper Electric Plane Talk 39 Aug 17, 2002 11:39 PM
What's the best all round sub $60 400 sized engine? AlexP Power Systems 6 Aug 02, 2001 09:21 AM
