This thread is privately moderated by corsair2014, who may elect to delete unwanted replies.
Aug 31, 2019, 11:12 AM
aerodynamics is just a theory
B-Wing Mk.2 - Hyperstalling FIXED!
Disappointed that some hyperstall/microstall tendencies persisted in the B-Wing mk.2, I was about ready to hack off the leading edge of the wing to give it a sharper profile. In fact, I even ran some quick CFD tests of different leading edge designs to see if my extra-round leading edge was causing premature flow separation or other problems.
Quick KFm2 Leading Edge CFD test (0 min 50 sec)
While those simulations were running I decided to go out to my secret test location and run a few other scenarios with the Mk.2 to see if I could reduce the microstalling further.
First Flight: removed the AA battery that was taped on for nose weight (24 grams). Hyperstalling immediately exaggerated and a new 'diving' or 'tucking' tendency arose making it impossible to fly straight and level
Second Flight: added back the AA battery and added a second battery (total 48 grams) for nose weight. Microstalling 99% eliminated! No more tucking and no more bobbing in regular turns (only in very hard, high-g loaded maneuvers which is somewhat expected)
---------Flight Video---------
https://www.instagram.com/p/B1pv_1Ln..._web_copy_link
So for now, I suppose that ends the B-Wing microstalling/hyperstalling mystery... sort of. By changing from a KFm-2 Airfoil to a KFm-4 I saw a large improvement in flight performance. And then by dialing in the CG I was able to eliminate 99% of the remaining issues. The aircraft still doesn't fly perfectly, but that is something that can be tuned in over time (I can live with this considering it has been over 3 years since I built a plane!).
Next Step: Get my FPV pod v2 finished up and go for an FPV maiden
New Product HGLRC 20x20 2-8S F405-WING (New) Flight Controller for RC Airplane Fixed Wing HGLRCFPV Multirotor Drone Electronics 1 May 22, 2019 05:07 AM
Question Apm 2.8 or pixhawk for fixed wing stabilization and waypoint navigation dropout Electric Plane Talk 9 Dec 06, 2016 06:39 PM
Discussion Learning heli & fixed wing at the same time, best to stick with mode 2 or 4? Hybone Electric Plane Talk 4 Nov 07, 2015 08:27 AM
Discussion Learning heli & fixed wing at the same time, best to stick with mode 2 or 4? Hybone FPV Talk 0 Nov 06, 2015 07:28 PM
