Aug 30, 2019, 03:24 PM
Car will only go forward slowly backward full speed
Hi.
I have a Helion Dominus 10TR with Reaktor 3500kV motor and Helion HRS-3.1 RC controller. It will only drive forward slowly but reverse full speed, I have re-bound the RC but it makes no difference. If I swap a pair of wires to the motor, it goes forward fast but only with the trigger pushed in the reverse direction. Any thoughts appreciated. Thanks
Aug 30, 2019, 05:13 PM
The speed control is operating in reverse , you need to reverse the throttle channel on the transmitter and swap two wires to the motor , that way the motor goes full power forward when you pull the trigger and slowly backward when you push it .
Sep 01, 2019, 06:42 AM
Thanks for that, but how do I reverse the throttle channel on the transmitter?
Sep 16, 2019, 08:16 PM
Its usually a switch " TH REV"
Sep 24, 2019, 04:05 AM
Fan of just about anything RC
SoloProFan's Avatar
Here's a link to the manual: http://helion-rc.com/dominus10SCv2/D...al_HLNA440.pdf
Reverse is covered on page 6, there is no reverse switch but a special rev button, apparently:
"• Throttle Reverse:
› Pull the throttle trigger completely to full throttle (or push forward for full brake) and press the “REV” button for at least 2
seconds to reverse the Throttle (TH) channel.
› The transmitter will beep once for confirmation of “Normal” and twice for confirmation of “Reverse” setting."
Latest blog entry: For the love of the hobby!
Discussion Speed controller for 4s-5s with forward and backwards for brushed motor skatun Batteries and Chargers 0 Jan 24, 2019 06:38 AM
Discussion Drone gain altitude after full pitch forward fallowing full backward pitch? samir_munir Multirotor Drone Talk 2 Jan 02, 2017 09:28 AM
Discussion quadcopter slowly accelerates and then goes full speed Colvid FPV Racing 1 Oct 07, 2016 12:13 AM
Discussion quad going very slowly backwards - help gainey Multirotor Drone Talk 0 Oct 21, 2014 12:48 AM
Discussion Trim Full Forward to Hover Without Going Backwards Heavy_D Beginner Training Area (Heli-Electric) 3 Sep 30, 2011 02:42 PM
