New Product
ZOHD KOPILOT Lite - Official thread
KOPILOT Lite is ZOHD’s first Autopilot System. Designed for the fixed-wing RC pilot (FPV and LOS) will give you peace of mind and a feature-rich unit in a very small and light-weight package.
Picture this: You’re about to maiden your very expensive EDF jet or super-scale Warbird. You know your nerves can bite you in the rear and have a bad time. KOPILOT Lite will make that maiden way smoother taking care of part of the flying until you get the feel of your new bird, giving you the chance to switch it off and have a full manual experience of you beloved machine. You’re new to FPV and overwhelmed with iNAV settings, bulk files, and hundreds and hundreds of pages of How to’s and user manuals. Forget all of that. KOPILOT Lite will give you a super easy setup (literally 10 minutes) and you’re off to the field. More time flying, less time researching. You’re an experienced FPV pilot bugged by clustered OSD’s with a lot of less info and unreliable software. KOPILOT Lite will put at your command, the basic functions for bringing your plane safely back home without getting in the way of flying. You will know KOPILOT Lite is there, only when you need it. FEATURES: Easy Installation, minimal wiring. Super easy setup Powerful stabilization and RTH algorithm Return to Home (RTH) Fence (RAD) and Stabilization modes on a 3 position switch Supports T-Tail, V-tail and Flying Wing / Delta configurations Mini-size GPS unit for ultra-light setups Fast SAT lock Adjustment board removable for a light-weight setup Launch assistant and motor blocking for no SAT fix AIL, ELE, THR, RUD + AUX to control your servos. Landing gear and flaps go straight to RX Computer-free programming Easy to transfer between planes Completely transparent. Switch it off and use it as a mixing board only More info soon! BUY here: https://www.aliexpress.com/item/4000143987613.html ImagesView all Images in thread
Here's the manual
I spent a hour setting one of these up yesterday
In the review sample I examined, the printed manual and Flight Controller behavior did not seem to agree, so one of them is wrong. The lighting pattern of the LEDs for what is labelled v-tail appears to actually be the wing mix, and I believe T-Tail was actually the v-tail I wanted.
In addition, I think the controller expects two channels to have reversed inputs from the norm - but not EVERY channel, just two. I haven't flown the plane yet, but I have low confidence I did not miss something else, and honestly won't be at all surprised if the plane crashes. It took a tremendous amount of guesswork that would be completely beyond your average novice. I firmly believe that a novice would likely crash or have completely unexpected behavior as it currently ships. Banggood has this at $45. If we assume the GPS is worth $10, that makes it about the same price as a Matek wing board, which actually has better documentation and a full-featured flight controller with OSD. For $25, working properly, and with better docs (what inputs belong on what channels, for example? It appears to expect AETR, but this is undocumented), it might have a market. But if nothing improves drastically in this product, I expect it will be gone in a year. |
Fence (rad)
When using the fence setting on return to home, which direction should the plane be facing when you arm the plane so when the return to home is triggered the plane will circle before it flys over your head. Which direction off the fc points toward he 100m area.
Thread Tools | |
Similar Threads | |||||
New Product | NEW ZOHD PLANE (Official): ZOHD Dart XL “Extreme” | SonicModell | FPV Aircraft | 3101 | Yesterday 10:15 PM |
New Product | ZOHD Nano Talon 860mm Wingspan ***Official Thread*** | guyst | FPV Aircraft | 4424 | Dec 07, 2019 01:33 PM |
New Product | NEW ZOHD PLANE (Official): ZOHD Talon GT “Rebel” | SonicModell | Product Announcements | 405 | Dec 03, 2019 04:35 PM |
New Product | ZOHD Orbit NEON (Official Thread) | SonicModell | FPV Aircraft | 47 | Nov 11, 2019 06:11 PM |
Poll | the official what is the real official sukhoi thread poll | dragrcr | Micro Ready-to-Fly | 29 | Jul 19, 2009 11:21 AM |
