Aug 29, 2019, 02:42 AM
Prekin's Avatar
Question
1/72 scale Revell, Airfix boat kit
Anybody experienced here who built some 1/72 scale boat kit like a Revell PT-109, Vosper or Airfix RAF Air sea rescue launch.
I would like to know some details what engine,batteries, shaft...
Thank you!
Aug 29, 2019, 04:23 AM
Do a search for contributor "rondean1". He has contributed some threads in the recent past which include information on the parts that he used when he did them.
Whatever parts you use to make it go, they need to be very light, and there is much need to save as much weight as possible from the build as the bare plastic model tends to float very near waterline.
A model with working bits added tends to float at its "deep loaded" waterline.
Just found your thread in scale.
Aug 29, 2019, 05:51 AM
Prekin's Avatar
Thank you mfr02
Aug 29, 2019, 02:28 PM
Big Boats Rule!
boater_dave's Avatar
What mfr02 said. If a PT is what you are after, the small Lindberg PT-109 is actually 1:64 scale, so it's a tiny bit bigger than the others. I used a 2S lipo and surplus motors. I made one set of props, and used a pair of nice Prop Shop ones ($$) for the other.
Dave
Aug 31, 2019, 07:29 AM
Boater Dave,
I've been meaning to ask you about your original Lindberg cutter motor set up. In your old set up you used a single Tamtech motor driving 2 pulleys attached to the twin prop shafts. I notice that both shafts rotate in the same direction. Did you have any problem with handling?
Sep 08, 2019, 11:01 AM
Fleet 4 Commanders
johnnyoverkill's Avatar
Ha!
I know those two other boats verrrry well! Up at Kohler too I might add!
Ahhh, back in the days when life didn't creep into my hobby!
Nov 19, 2019, 02:51 PM
Big Boats Rule!
My apologies, Redboat219, I didn't see your reply until now. The boat is so small you don't notice much unless you do a lot of backing up. I converted it over to twin motors and the operation is a little better, but not much.
John! How the heck are you? Long time between talks. I should be down your way with those 'other' sailboat guys on the west side sometime in January.
Dave
Question 1/72 scale Revell, Airfix boat kit Prekin Scale Boats 5 Aug 30, 2019 05:50 AM
Discussion 1/72 Airfix Vosper Motor Torpedo Boat RC convertion f6f Micro and Sub-Micro Boats 8 May 27, 2014 02:40 AM
Discussion AIRFIX E BOAT 1/72 scale Minigear test rondean1 Scale Boats 6 Jul 08, 2013 06:02 AM
Discussion New Airfix 1/72 kits for Minigear rondean1 Scale Boats 0 Jun 22, 2013 05:04 AM
Barnstormer Boats 1:72 scale LA Class kit review. Nemo Submarines 8 Mar 21, 2007 07:51 AM
