This thread is privately moderated by Martin Zhuang, who may elect to delete unwanted replies.
Aug 29, 2019, 02:19 AM
New Product
HGLRC Parrot120 FPV Racing Drone PNP F411 Flight Control 13A 4in1 ESC 1103 Motor
Item Name: HGLRC Parrot120 FPV Racing Drone PNP
Net Weight:54.9g
HGLRC Parrot120 Frame Kit
Material: Carbon Fiber
Wheelbase:120mm
Type: 2.5" Frame
Arm Thickness: 2.0mm
Standoff Height: 23mm
Flight control installation holes: 16*16mm
Support camera: 14X14mm
Weight: 15g
HGLRC FD411 Flight Controller
Item Name:FD411 Flight Controller
MPU: MPU6000-SPI
CPU: STM32F411CEU6
Black Box: NO
Input Voltage: 2-4S Lipo
Built-in Betaflight OSD to adjust PID
BEC Output: 5V 2A
Installing Hole: 16x16mm, M2
Support SBUS/PPM/DSMX/iBUS receiver
Weight:2.7g
HGLRC FD13A 4in1 BLS 2-4S ESC
Item Name: FD13A 4in1 2-4S ESC
Constant Current: 13A
Peak Current: 15A(5S)
BEC Ouput: NO
Weight: 3.2g
CPU: SILABS EFM8BB2 48MHZ
MOS Tube: TOP QUALITY MOSFET
Support Damped Mode:DSHOT600/300/150/Oneshot125/42,MultiShot,PWM
HGLRC FD VTX Micro 400mW
Item Name: FD VTX Micro
Output Power: PIT/25mW/100mW/200mW/400mW Switchable
Input Voltage: DC 5V
PIT---------0dBm------70mA
25mW-----14dBm-----150mA
100mW----20dBm-----210mA
200mW----23dBm-----280mA
400mW----26dBm-----360mA
Antenna: IPEX
Weight: 1.5g
Caddx.us Turbo Eos2 FPV Camera
Item Name:Turbo EOS2
Image Sensor:1/3" CMOS
Horizontal Resolution:1200 TVL
TV System:NTSC / PAL option
IMAGE:16:9
Synchronization:Internal
Electronic Shutter:PAL: 1/50-100,000
NTSC: 1/60-100,000
S/N Ratio: >52dB (AGC OFF)
Video Output:CVBS
Lens:2.1mm
Auto Gain Control:YES
BLC: YES
WDR:Global WDR
DNR:2 DNR
Dimensions:14mm"14mm*16mm
Input PowerC 3.3-6V
Working Temperatur:-20℃~+60℃
Work Humidity:20%~80%
Net weight:3.5g
HGLRC FD1103 8000KV Brushless Motor
Item name:FD1103 8000KV Brushless Motor
Motor:KV8000
Stator Diameter:11mm
Stator Thickness:3mm
No.of Stator Arms:9S
No.of Rotor poles:12P
Motor Resistance:330mΩ
Max Continuous Current:5.46A
No.of Cells(Lipo):2-3S
ESC:6A
Recommended Prop(inch):2.5 Inch
Wire type:28AWG x 40mm
Weight:4g
Gemfan 65mm 2.5Inch 2-Blade Propeller
Quantity: 3 CW & 3 CCW
Package Included:
1x FD411 Flight Controller
1x FD13A 4in1 BLS ESC
1x FD VTX Micro
4x FD1103 8000KV Brushless Motor
1x Parrot120 Frame Kit
1x Caddx.us Turbo Eos2 FPV Camera
6x Gemfan 65mm propeller
1x IPEX Antenna
