Aug 28, 2019, 11:56 PM
foxtechtech's Avatar
New Product
3300mm Wingspan VTOL: Foxtech Great Shark
FOXTECH Great Shark 330 VTOL
https://www.foxtechfpv.com/foxtech-g...-330-vtol.html
More Payload and Higher Efficiency Mapping VTOL: Great Shark 330 (6 min 14 sec)
Great SHARK 330 VTOL has a 3.3 meter wingspan, and features a highly advanced aerodynamic design. The fuselage of Great SHARK 330 is made of Kevlar material which is very light and durable.
Although the Great Shark is so big, it adopts quick-detach design which makes the plane easy to assemble and disassemble, and easy to transport. The fuselage also has big inner space for flight controller, batteries or other equipments, like oblique camera etc.
The Great Shark 330 VTOL can fly longer and load more payload. The max. payload is about 5kg. The frame of Great SHARK is 6kg, and max take-off weight is about 20kg, and the fly time is around 2.5 hours. The cruising speed of the Great SHARK can reach 26m/s. The Great Shark 330 VTOL can take off and land vertically in a very small area.
In this Great SHARK VTOL plane we suggest to use two 6S 10000mAh Lipo for VTOL mode, and four 6S 12500mAh Li-ion battery for Fixedwing mode. The Great Shark 330 VTOL equipped with FH230 TR 30X Optical Zoom Camera and gimbal can be used to do long range inspection, equipped with3DM V3 Oblique Camera or Map-A7R can be used to do 3D modeling, oblique mapping and ground survey etc.
Note: The Great Shark will be shipped 7 days later after the order is made, please contact customer service staff for specific delivery date.
Specification:
Wingspan: 3300mm
Length: 1750mm
Frame Weight: 6.35kg
Take-off weight: 9kg(w/o battery, payload)
Max take-off weight: 20kg
Endurance: 2.5 hours
Suggest Max. Payload: 5kg
Cruising speed: 22m/s
Battery: 2x 6S 10000mAh Lipo(VTOL mode), 4x6S 12500mAh Li-ion(fixedwing mode)
Take-off/Landing: VTOL
Aug 29, 2019, 09:40 AM
Aka: Tom Jenkins
ApexAero's Avatar
A friend built one for a client, pretty nice setup but the gear costs almost as much as the model! Makes for a limited market huh?
Aug 29, 2019, 07:35 PM
Black Cloud's Avatar
Doesn't really look like a flying wing to me either...
Discussion Foxtech baby shark 260 vtol foxtechtech VTOLs 0 Jan 24, 2019 06:19 AM
Discussion Tutorial Material Summary for Foxtech Nimbus Mapping VTOL foxtechtech FPV Aircraft 2 Jul 13, 2018 12:57 AM
New Product Foxtech Nimbus 1800 VTOL Mapping Version Released foxtechtech FPV Aircraft 1 Jun 05, 2018 07:52 AM
News Foxtech HUNTER-280 VTOL Aircraft - WOW Jim T. Graham VTOLs 10 Jan 09, 2018 12:13 PM
