This thread is privately moderated by kopterheld, who may elect to delete unwanted replies.
Aug 28, 2019, 10:38 PM
Mini-Review
Eachine Cinecan 4K best CineWhoop
Eachine Cinecan 85mm 4K - CineWhoop- Banggood Coupon: BGWKcinecan
http://bit.ly/EaCineCam
This is the 85mm CineWhoop from Eachine with the good Caddx Tarsier that can record 4K, but more importantly that it has a very good FPV camera. The Cinecan flies well and is not as heavy as Beta85X 4K. The video footage is very good, but it shakes a bit, especially if you give too much throttle or it is windy outside. What I really like on the Eachine Cinecan is that it flies perfectly in Acro mode without a washout.
Pro:
- best FPV and HD 4K camera
- Very light as a 4K CineWhoop
- strong 1103 motors
- Video transmitter 25-200mW
- F4 FC with 10A ESC
- external receiver like CrossFire
- flies very well in Acro Mode
- ND8 filters
Cons:
- Video trembles
- not durable
Video 1 - Eachine CineCan 4K Review
Eachine Cinecan 4K CrossFire Nano CineWhoop Review deutsch (5 min 15 sec)
Video 2 - Roman Treadwheel crane
Eachine CineCan 4K Whoop - Römer Kran (1 min 59 sec)
Suitable batteries:
BETAFPV 300mAh 3S 45C - https://amzn.to/2ZkvZS7
GNB 300mAh 3S 45C - http://bit.ly/Gnb3s80c
GNB 300mAh 3S 30C
Banggood - http://bit.ly/Gnb300mAh3S
Amazon - https://amzn.to/2xg3kOx
Happymodel 300mAh 3S 30C
Banggood - http://bit.ly/M7Hd300mAh
Amazon - https://amzn.to/2IQ4zdY
Picture 1 - 4K on top and bottom the FPV lens
Picture 2 - 4K on bottom the 300mAh 3S 30C LiPo
Picture 3 - 4K right button for start and stop the video recording, long press for WLAN (5 sec), left button to switch the record mode
Picture 4 - Soft case for the Cinecan
Picture 5 - 3 screws on the 1103 motors
Picture 6 - 3 powerful 1103 motors 7000KV
Picture 7 - CrossFire nano receiver for best range
Picture 8 - CrossFire nano flexible antenna - works great
Picture 9 - Micro SD Card Slot for HD or 4K recording
My configuration with CrossFire Nano receiver
The PID values are original from the Eachine Cinecan.
CrossFire Nano uses the serial ports pinouts: RX2 and TX2. SmartAudio is soldered to TX1.
If an R-XSR or XM Plus receiver is used then iRX1 will be used for SBUS input and camera SmartAudio will be soldered to TX2.
On the Eachine Cinecan Betaflight 4.0.5 is installed with my following changes:
# diff 2019-08-25
# Betaflight / CRAZYBEEF4DX (C4DX) 4.0.5 Aug 1 2019
batch start
name cinecan
feature -TELEMETRY
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -CRASH_FLIP
beacon RX_LOST
beacon RX_SET
map AETR1234
serial 0 2048 115200 57600 0 115200
aux 0 0 0 1675 2100 0 0
aux 1 1 1 900 1300 0 0
aux 2 2 1 1300 1700 0 0
aux 3 13 2 1700 2100 0 0
aux 4 35 2 1700 2100 0 0
aux 5 47 2 1300 1700 0 0
rxrange 0 987 2011
rxrange 1 987 2011
rxrange 2 987 2011
rxrange 3 987 2011
set acc_calibration = -27,-5,47
set rssi_channel = 8
set serialrx_provider = CRSF
set motor_pwm_protocol = DSHOT600
set vbat_max_cell_voltage = 450
set vbat_min_cell_voltage = 320
set vbat_warning_cell_voltage = 330
set ibata_scale = 470
set beeper_dshot_beacon_tone = 5
set small_angle = 180
set deadband = 4
set yaw_deadband = 4
set pid_process_denom = 1
set osd_warn_esc_fail = OFF
set osd_vbat_pos = 2091
set osd_rssi_pos = 2081
set osd_tim_1_pos = 54
set osd_tim_2_pos = 2102
set osd_flymode_pos = 2456
set osd_g_force_pos = 65
set osd_throttle_pos = 2423
set osd_crosshairs_pos = 2253
set osd_current_pos = 2400
set osd_mah_drawn_pos = 2433
set osd_craft_name_pos = 2443
set osd_warnings_pos = 329
set osd_disarmed_pos = 2379
set vtx_band = 1
set vtx_channel = 2
set vtx_power = 3
set vtx_freq = 5845
profile 0
set p_pitch = 50
set i_pitch = 50
set d_pitch = 30
set f_pitch = 60
set p_roll = 50
set i_roll = 45
set d_roll = 27
set f_roll = 60
set p_yaw = 72
set i_yaw = 55
set f_yaw = 100
set angle_level_strength = 85
set level_limit = 85
rateprofile 1
set roll_expo = 23
set pitch_expo = 23
set roll_srate = 75
set pitch_srate = 75
set throttle_limit_type = SCALE
set throttle_limit_percent = 65
rateprofile 0
set roll_expo = 23
set pitch_expo = 23
set roll_srate = 75
batch end
Original configuration
Eachine CineCan with CrossFire was the original Betaflight 4.0.4:
# diff 2019-08-21
# Betaflight / CRAZYBEEF4DX (C4DX) 4.0.4 Jun 30 2019
batch start
name cinecan
feature -TELEMETRY
feature -AIRMODE
feature MOTOR_STOP
beeper -ARMED
aux 0 0 0 1300 2100 0 0
aux 1 2 1 1200 1550 0 0
aux 2 28 1 1550 2100 0 0
set rssi_channel = 12
set vtx_band = 1
set vtx_channel = 2
set vtx_power = 3
set vtx_freq = 5845
profile 0
set p_pitch = 50
set i_pitch = 50
set d_pitch = 30
set f_pitch = 60
set p_roll = 50
set i_roll = 45
set d_roll = 27
set f_roll = 60
set p_yaw = 72
set i_yaw = 55
set f_yaw = 100
rateprofile 0
set roll_expo = 23
set pitch_expo = 23
set roll_srate = 75
batch end
More good RC parts coupons on my blog:
https://kopterheld.wordpress.com/2018/01/01/news/
New Kopterheld coupons on Telegram App or FB:
https://t.me/KopterHeld
http://bit.ly/KhFaceBo
My equipment: (Banggood)
Fatshark Dominator HDO - http://bit.ly/BgFaHDO
ImmersionRC RapidFIRE - http://bit.ly/BgRapidFire
FrSky TARANIS Q X7 - http://bit.ly/2zLLvJq
FrSky X9D Plus SE - http://bit.ly/2z4KxXG
iRangeX IRX4 Plus Multi Module - http://bit.ly/2QrTIeT
FrSky R-XSR - http://bit.ly/2S6rNyc
RunCam Racer 2 - http://bit.ly/2BZJCtq
RunCam Micro Eagle - http://bit.ly/2BPNnkL
FaceBo http://bit.ly/KhFaceBo
Blog https://kopterheld.tv/
RCGroups https://goo.gl/JYP87D
Telegram - https://t.me/KopterHeld
Instagram - https://instagram.com/kopterheld
Twitter - https://twitter.com/kopterheld
New Product Eachine Cinecan 85mm 4K Cinewhoop Review JohnCC Micro Multirotor Drones 13 Oct 15, 2019 07:44 AM
Discussion Eachine Cinecan / 4K Cinewhoop /3-4S BG-Wilson Multirotor Drone Talk 38 Oct 11, 2019 02:15 AM
