Aug 28, 2019, 08:31 AM
Question
Apprentice rtf , throttle/motor does not activate
Ugh. Brand new plane, start up sequence followed, rudder/elevator/airleons all work, but no throttle. Only a annoying sqeual. I charged battery properly per instructions and confirmed with battery checker, trimmed down the throttle and lowered all the way before turning on. Any thoughts on the issue?
Sent from my moto g(7) using Tapatalk
Aug 28, 2019, 10:41 AM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
When you hear the annoying squeal , does it look like the prop is trying to move ?
Did you take off the prop & cowling to install the landing gear ( as per manual ) ?
Take off the prop & cowling , and then see if the motor/throttle will work . If it does , the prop/cowling was installed improperly and caused binding . If the motor/throttle doesn't work and makes the squeal noise , check the connections on the three wires going to the motor ..... one or more may have a poor connection .
Aug 29, 2019, 01:21 PM
Let us know if you found/fixed the problem .
Aug 30, 2019, 08:45 AM
No luck yet.. prop not binded, wires have good connection... Back to hobby shop to see what they can do.
Aug 30, 2019, 10:23 AM
AeroDan
As another Apprentice owner, please let us know what’s going on, OK.
Aug 30, 2019, 11:08 AM
JohnFM's Avatar
As a new model the store where you bought it should replace it.
Off hand I'd suspect the ESC.
Aug 30, 2019, 11:55 AM
Did you test the motor/throttle with the prop and cowling off ?
Aug 30, 2019, 02:43 PM
The Other Side of Your Screen
SilverSport's Avatar
The preflight checklist didn't mention arming the motor/esc turning on the switch under the wing .... unless they don't do that anymore. But it usually would not squeal in that case. He also did not mention of he heard the 3 beeps when the battery was connected ... as the beeps come from the motor.
Sep 05, 2019, 09:15 AM
Resolved: inconsistent battery connection. Perhaps the connectors will loosen up with use, but I have to exert lots of pressure to connect battery to ESC lead. As a result, sometimes I get the three beeps for motor, sometimes I don't. The battery lead from ESC is literally the exact length it needs to be to connect with battery. I like clean wiring but a little extra length on the lead would make connecting battery much easier. Thanks for tips!!
Sep 05, 2019, 11:53 AM
Took my Apprentice out this weekend .... even attempted a glider pull ... it wasn't pretty but that's another story.
So I connected my battery with switch off for radio gear. I can't say if the ESC armed or not, but I think it did. Had to wait for other traffic before we made the attempt, when ready I turned the switch on, the activation happened and went to takeoff .... no throttle. Well I have been there before and on the runway with help of glider pilot disconnected and reconnected battery, got the beeps, powered on radio and got to the not so pretty attempt to tow glider.
Maybe with a Power 25 and higher pitch prop it could do it, but that glider was too heavy for the stock 145 flight 5 year old Apprentice. I'll keep flying it as I have, T&G practice and getting newbies on the remote student box's sticks.
Sep 05, 2019, 11:54 AM
Glad you solved it. Get some flights in, this issue will probably happen again, as it did to me.
Discussion brushless motor does not start at low throttle with new gears necbot Electric Power Cars 1 Jul 11, 2019 11:18 PM
Help! Motor Model does not match data for low Throttle! Glosh Power Systems 2 Dec 26, 2017 03:49 PM
Discussion DX8 Spectrum Throttle Always High -- Throttle Reverse Does Not Work gwfalcon Radios 6 Nov 02, 2016 01:00 PM
Discussion MW 2.2 FAILSAFE actives, does not shut down motors njacobs Multirotor Drone Talk 0 Oct 09, 2013 01:55 PM
Rant Why does tail motor not have authority after half throttle?? markswift Micro Helis 9 Jun 06, 2004 03:26 AM
