Jun 06, 2020, 01:45 AM
OTX OG and EdgeTX contributor
3djc's Avatar
Originally Posted by timflyerfry View Post
Potential Bug:
TX: Horus X10S Express running 2.3.8n231. SD Card contents v-29
Module: R9M 2019
RX: R9 Mini OTA
When attempting to update my R9 Mini OTA with the OTA option, I chose Flash via OTA and then powered on the RX, but I had to hit RTN in order to get the receiver selection to pop up so that I could select the RX. Everything worked fine after that.
To further test, I powered the RX before choosing the OTA update option. As expected, the TX didn't find the RX, but when I hit return, the TX would not navigate away from the "Waiting for RX" screen. I had to cycle the RX power, hit RTN, select the RX, and then the RTN button allowed me to cancel the update process.
Made an issue : https://github.com/opentx/opentx/issues/7684
Not sure any of use does have the equipement required to duplicate tho
Jun 06, 2020, 11:42 AM
Anything else I can do on my end to help?
Jun 06, 2020, 12:00 PM
Guys, we are nearing completion of 2.3.8, it would be great if some of you could download 2.3.8N230 (https://downloads.open-tx.org/2.3/nightlies/companion) in an hour or two when it becomes available and flash their radio with the 2.3.8n230 firmware and report issues, if any.
You can get an idea of what is included here : https://github.com/opentx/opentx.git...2.3.8?expand=1
I found another potential bug:
TX: Horus X10S Express, 2.3.8n231
I have categories setup on my model selection page and every time I navigate to the Model Selection page, the category defaults to what ever category was selected when I power on the radio, regardless of whatever category was last used.
Is this how it is designed or is the model category supposed to default to the last used category?
Jun 06, 2020, 12:15 PM
3djc's Avatar
Works like that, a suggestion to improve has already been submited
Jun 06, 2020, 12:17 PM
Thanks!
Jun 07, 2020, 04:11 AM
OTA updates ACCESS G-RX8 ?
what is about OTA updates with ACCESS and G-RX8 and RX4R ?
(how) does it work?
the SD menu does not give me that option with 2.3.7 in horus x10s/upgrade and X-Lite-S
Jun 07, 2020, 04:17 AM
Happy FPV flyer
Kilrah's Avatar
Only the receivers with OTA in the name support that. While those 2 RXes support ACCESS they do not support OTA.
Jun 08, 2020, 08:05 AM
Regexistentialist
ridgerunr's Avatar
Where did the X9Lite thread go?
Where did the X9Lite thread go? I can't for the life of me find it!
(I'm experiencing intermittent signal loss after upgrading RX and TX to ACCST 2.1.0. IIRC there was a bug that I read about but cannot find the thread that was discussing it.)
Also, I see that older threads seem to fall off the edge of the RCG world after 12 pages or so?
Jun 08, 2020, 09:00 AM
in awe of glide...
Kirkerik's Avatar
Jun 08, 2020, 09:09 AM
Regexistentialist
ridgerunr's Avatar
Those are the ones - Thanks!
(My search term: "X9Lite" failed - it needed a space.)
Thanks again!
Jun 08, 2020, 09:45 AM
Pompano Hill Flyers
Miami Mike's Avatar
It's unfortunate that the OPs (Jet_Flyer and Frimen) chose to group all of those different radios into the same threads. It's one of the reasons that they get so large and become unsearchable.
Latest blog entry: How To Get a Custom AMA Number
Jun 09, 2020, 02:58 PM
I tested the OTA function with 2.3.8N241 nightly on my Horus X10S Express and everything appears to be working as it should. Thanks.
Jun 09, 2020, 03:11 PM
3djc's Avatar
Cool thanks for the update
Jun 11, 2020, 11:27 AM
Taranis X9D+ SE 2019, Trainermode Master/SBUS Module. Can an SBUS RX be connected to the heartbeat pin here?
Discussion OpenTX Model Programming Thread RC Grouper Radios 2321 Yesterday 10:25 PM
Discussion Pixhawk 2 (un)official discussion thread Rusty105 Multirotor Drone Electronics 212 Aug 15, 2023 09:26 PM
Discussion Official OpenTX version 2.2.3 Discussion Thread RC Grouper Radios 32 Jun 11, 2019 08:59 AM
Discussion Official Drone Registration Discussion Thread **Discussion Here** bansheerider Model Aircraft & Drone Advocacy 4320 Dec 07, 2017 01:53 AM
Yippee! Official Portal 2 Discussion Thread Miami Mike Chit Chat 9 May 02, 2011 08:19 AM
