Aug 28, 2019, 01:22 AM
pafleraf's Avatar
Official OpenTX version 2.3 Discussion Thread
Good morning everyone!
As we are moving forward towards the 2.3 release, more tests are needed. As of now, all the supported targets have been opened to the nightlies and it seems we already have something working quite nicely.
There are still a couple of minor things to come, but the binary format is now settled, Companion and all the radio firmwares should be working with it (including proper conversions from 2.2.x). The times have come to now fix everything we can find and finalise the release.
As this is still in beta state, it is a good idea to backup everything you have on 2.2 before testing on the 2.3 branch. For those already on nightlies (new radios), doing backups is still a good idea, so you can always revert to the previous working state in case something slips through the QA.
Links:
http://www.open-tx.org/2019/05/17/2.3-nightlies
Please remember that you have to configure "Use nightly builds" in Companion (Settings / Application settings).
Changelog (for now, will be updated):
New radios
  • X-Lite Pro
  • X9 Lite
  • X10(S) Express
  • X9D+ 2019
  • T12
ACCESS support
  • Support up to 24 channels on ACCESS modules when using ACCESS protocol
  • Spektrum analyser and power meter on compatible ACCESS modules
  • New registration and bind mechanism for ACCESS devices
  • Support for OTA updates for upcoming compatible hardware
Lua
  • Fix TIMEHOUR handling on 128x64 screens
  • Telem 1 to (40/60) items added
  • Lua mix scripts outputs added
  • Fix DIY first ID to 0x5100
  • Introduction of virtual navigation keys
Companion
  • Fix for Negative GVAR precision (Thx Elecpower)
  • Add receiver number to model list (Thx Elecpower)
  • Add Japaneese translation (Thx Ku2works)
Frsky
  • Latency for existing XJT modules (internal or external) has been significantly improved
  • Support for Neuron lines ESC telemetry
  • Support for .frsk firmware files. Those contains identification of target hardware, preventing flashing wrong device with wrong firmware type errors
  • Due to an FrSky bug in Bluetooth modules, BT radio names have to be in lower case only
Taranis
  • Taranis now allow up to 40 sensors (up from 32)
  • Support for additional switches for X7 on PAD400 and PAD401
  • Support for X9D REV4a removed (wasn't compiling since 2.2)
  • 'full size' modules available on small size external bay as an option
  • X9E : prevent timer display overflow on top LCD
  • 128x64 : fix trims display
Horus
  • Horus now allows up to 60 sensors (up from 32)
  • Support for additional switches and pots for X10 and X12
  • Screenshots
Sky9x
  • Add R9M flex option to Sky9x
  • Support for Sky9X REVA removed (wasn't compiling since 2.2)
  • Fix for PPM2 not properly initialised
Jumper
  • Add support for Jumper T12
  • Radio protocols
  • Add Crossfire telemetry mirror on serial port
  • Add iNav vario sensor to Crossfire
  • Support for Multimodule 1.2.1.51 (Thx MRC3742 and PascalLanger)
  • Disable RxNUm checks for D8 protocol
  • Mixer to pulse synchronisation improved
  • Display FlySky volts as signe values (Thx CapnBry)
Miscellaneous
  • Improve rotary encoder handling on all radios
  • Improve Czeck translations (Thx Jannek)
  • Improve German translation (Thx SHezinger)
  • Improve Italian translations (Thx mzambrini)
  • Fix GPS distance callulation on some coordinates
  • Update to latest multiprotocol revision
  • RTC Voltage monitoring + alarm (thanks to Mike B)
  • RADIO / TOOLS menu
Aug 28, 2019, 02:13 AM
pafleraf's Avatar
reserved
Aug 28, 2019, 04:14 AM
Have Fun and Just Fly!
l shems's Avatar
Is there some documentation on this:
* Introduction of virtual navigation keys
I am prepared to create some proper documentation, if I get some stuff to start with.
Aug 28, 2019, 04:40 AM
pafleraf's Avatar
This is I have for now: https://github.com/opentx/opentx/pull/6500
Hope it's enough to grasp the essence.
Aug 28, 2019, 06:10 AM
Hi All,
I'm testing the nightlies build 2.3.0 N70 on my Taranis X9-Lite with Vantac MPM Lite module attached:
My Whoops are
Beta75 Pro 2
Bee Brain v2
Bee Brain Lite
Working like a charm
Credits to the OpenTX Dev Team that have gotten 2.3 thus far. Without your Dev work, my radio would have been shelved. Thank you.
Aug 28, 2019, 06:33 AM
l shems's Avatar
Nice. Almost an exact copy of my Lua event handler to manage it myself, that I use up till now.
Where should I enter the documentation? Is the auto-generated documentation still working?
Aug 28, 2019, 06:35 AM
l shems's Avatar
Linked question: event support for widgets there already?
RC Grouper's Avatar
This is the official discussion thread for OpenTX version 2.3. The official thread for version 2.2 can be found at
https://www.rcgroups.com/forums/show...cussion-Thread
Aug 28, 2019, 06:39 AM
pafleraf's Avatar
It’s on my todo list for the next days.
Aug 28, 2019, 06:47 AM
l shems's Avatar
Using only virtual events? Or both?
Aug 28, 2019, 06:50 AM
pafleraf's Avatar
Using all the events that would get passed usually to LUA script, except those that are used on the main screen view. Once I have some code, you can probably test and give me some feedback.
Aug 28, 2019, 07:46 AM
Happy FPV flyer
Kilrah's Avatar
Irrelevant now, duplicate thread was merged.
Aug 28, 2019, 08:23 AM
pafleraf's Avatar
Originally Posted by RC Grouper
This is the official discussion thread for OpenTX version 2.3. The official thread for version 2.2 can be found at...
This is really getting kind of funny, let's see where this takes us
Aug 28, 2019, 09:15 AM
Some more items for the list:
2 new radios supported:
- X10 Express
- X9D+ 2019
On Bluetooth front there is the selection of the device to connect to, increased refresh rate (by a factor of 2)
Screenshots on X10 / X12S
That's all I have in mind now
Aug 28, 2019, 09:16 AM
Discussion OpenTX Model Programming Thread RC Grouper Radios 2321 Yesterday 10:25 PM
Discussion Pixhawk 2 (un)official discussion thread Rusty105 Multirotor Drone Electronics 212 Aug 15, 2023 09:26 PM
Discussion Official OpenTX version 2.2.3 Discussion Thread RC Grouper Radios 32 Jun 11, 2019 08:59 AM
Discussion Official Drone Registration Discussion Thread **Discussion Here** bansheerider Model Aircraft & Drone Advocacy 4320 Dec 07, 2017 01:53 AM
Yippee! Official Portal 2 Discussion Thread Miami Mike Chit Chat 9 May 02, 2011 08:19 AM
