Aug 27, 2019, 01:13 PM
A.C.E/AAF Tank Museum Battle weekend. Sept. 13-15 2019
Hello Tankers and r/c enthusiasts, A.C.E and the AAF tank museum will be hosting another great r/c tank event at the AAF tank museum in Danville VA September 13-15. Come check out the action of fully realistic tanks using IR to battle. We will be using stock apple configuration unless the tank has a fixed structure then TFA is allowed. No IFA is permitted. We'll be running the "Rolling Thunder" type scenarios which emphasize team work and variable we will apply to battles as we go through the weekend. This is a great chance to check out 1/16 tanking at it's best even if you don't have a tank or not IR equipped. Not too mention the museum is an AMAZING place to visit and see all kinds of vehicles, small arms, uniforms, etc. Make sure to get your tanks in running order to make inspection go quick. If you need a hotel room for the weekend most stay at the Comfort Inn which is just a couple minutes down the road from the museum. If you have any questions at all PM me or post up. I've include the museum's website as well as the weekend schedule and a "cheat sheet" for Rolling Thunder. As for inspections we will be doing a quick one over for the following criteria to make an even playing field. Looking forward to seeing old friends and meeting some new ones!
Tank dies according to class.
Tank takes hits from 4 cardinal angles.
No apple obstructions.
IR emitter tube 6mm ID with depth of 9mm to front of bulb minimum.
Scale ON road speed for tank.
Flash or barrel recoil.
https://www.aaftankmuseum.com
Discussion N.E.A.D/AAF tank museum battle weekend. Nov. 9-11 2018 TheBennyB RC Tanks 0 Nov 06, 2018 02:11 PM
Discussion A.C.E/AAF Battle weekend Danville, VA. Sept 14-16 2018 TheBennyB RC Tanks 4 Sep 12, 2018 08:45 AM
Discussion A.C.E/AAF Tank Battle Weekend. March 16-18 2018 TheBennyB RC Tanks 4 Mar 16, 2018 05:10 AM
Discussion ACE/AAF Battle Weekend Danville VA September 15-17 2017 CustomRCmodels RC Tanks 0 Sep 03, 2017 10:06 AM
Discussion ACE/AAF Rolling Thunder tank battles Danville VA Sept 16-18 2016 TheBennyB RC Tanks 1 Sep 12, 2016 12:41 PM
