Aug 27, 2019, 05:03 AM
MZ24 Firmware update and Trainer problems
Hi All...
Hope you guys can help... I have an MZ-24 that is currently version 1.021. Trying to update. Have latest version of studio. Can read the device data with product info read, but fails with error return address : 8004000 when trying to update firmware.
Have downloaded 55.bin and 56.bin files..
Need to update as I have problems with using the Trainer system.
Master Transmitter Mode 1 Version 1021
Student Transmitter Mode 2 Version 1024.
Ailerons selected as 2 ailerons both systems. Individually both work ok.
When using as Student the ailerons only work as 1 aileron.
Need to make the firmware the same and then work out the problem.
Thanks in advance
Aug 27, 2019, 10:18 AM
Graupner USA's Avatar
Make sure that you do not move any of the controls of the TX prior and during the update.
There is a video that shows how to update.
Part 1 mz-18 / mz-24 to mz-18 / mz-24 PRO - Radio Preparation (3 min 27 sec)
Aug 27, 2019, 10:28 AM
Below is a link to recent posts about the Firmware update process for the MZ24 to the PRO Version. Of course you don’t have to Upgrade to the PRO Version. Although I recommend it, as the PRO adds some nice capabilities. The MZ24 / MZ24-PRO is a very nice radio and I still use it frequently even though I also have the MZ32.
In any case download the Firmware 1.057 as provided by GraupnerUSA and update your Firmware to the most up-to-date.
Check post #7
https://www.rcgroups.com/forums/show...-use-in-planes
As I have said this does not require to proceed with the PRO Upgrade, but I would recommend it. Here is the link, if you decide to do so.
https://www.graupnerusa.com/Firmware...6.PRO.UPD.html
Aug 31, 2019, 09:12 PM
Trainer problems
Thanks all,
I have he problem sorted out now.
Discussion Problems updating FlySky F-I10 Firmware Shinjo01x Radios 7 Feb 15, 2018 01:59 PM
Mini-HowTo ISDT SC-620 Smartcharger only Chinese problem and a trick for update firmware mrlocchoc Batteries and Chargers 8 Sep 29, 2017 03:29 AM
Discussion Graupner mz-12 firmware update problem JB_Jacobo Radios 3 Sep 01, 2016 05:10 PM
Discussion SP3 EVO firmware update problem Milkco72 Multirotor Drone Talk 1 May 11, 2016 07:51 PM
