Aug 26, 2019, 04:12 PM
RC flight's Avatar
Dash-8-100
Hey guys,
Today I took my Dash8 up for the first time. It was the toughest flight I have ever experienced due to a few things such as being tail heavy, airfield being far too small, the plane being far too heavy and fast. But I am extremely great full to have it back on the ground in one piece!
I have decided the model is in need of severe weight reduction and flaps. An electric conversion is now underway!
Length=56.5
WS= 76.25
AUW=13.14lbs
I was lucky enough to purchase the model from an older gentleman. It is a scale replica of a Dash-8-100. It has a molded FG fuse/Vstab. The wings centre section is balsa with balsa covering. Outer wing is foam core with balsa sheeting.
I have removed the nitro related components which come out to a total weight of 1876g= 4.13lbs including fully fuelled tanks.
Im aiming for a weight saving of close to 3lbs.
I am seeking some advice as to which motors would work best for a model of this size? I already own two 60a ESCs with 80a burst. I also have 3s 2200mah 40-50c lipos I was thinking of running paired up but Im thinking 4s would be better.? Would the E-flite 10: 900kv EFLM17553 be a good choice for a 4 blade prop?
Any help/input would be great!
Jake
Aug 26, 2019, 06:13 PM
Which props?
I've found that 4s works great for twins of about 80 inch
Verstuurd vanaf mijn SM-A405FN met Tapatalk
Aug 26, 2019, 07:20 PM
RC flight's Avatar
Thanks.
I would like to run 4-blade props. The size would depend on the motor and battery choice. I would also like to find chrome spinners to finish them off.
Sep 16, 2019, 02:01 PM
Long-Time Member
James Frolik's Avatar
Perhaps take a look at this for a 4-blade prop.
There are a few older videos that describe the VarioPROP.
Video #1
Video #2
Oct 05, 2019, 02:34 PM
An itch?. Scratch build.
eflightray's Avatar
Just came across this ---
BRAND NEW STUNNING !!! DASH 8 Q400 LIGHTWEIGHT 550 GRAM INDOOR RC MODEL AIRLINER FLIGHT DEMO (5 min 13 sec)
Jan 10, 2020, 08:36 PM
Very nice Dash 8. Please make room for messages in your PM file. Your folders are full.
Rob
Jan 12, 2020, 06:30 PM
Jake
I hope you can make a saving of 3 lbs. Electric conversions don't normally give a huge saving in weight. Any saving will of course help but I fear it wont fundamentally change the way it flies.
The smooth nature of electric power allows a plane to be built lighter in the first place.
My Dash 8 Q400 is a bit smaller with a span of 61" but the fuselage is longer at 76". As a result it had to be built 'silly' light (2 lbs all up!) to fly at a reasonable speed which it does using very modest power.
Description:
Build Log Dash -100 build started, finally!! Doug Bartley Giant Electric Planes 405 May 29, 2018 05:20 PM
Discussion Dash-8-100 Joe Yap Scale Kit/Scratch Built 25 Dec 30, 2016 02:21 AM
Help! DHC-8/Dash 8/Bombadier srt8madness Scale ARF/RTF 10 Jun 04, 2013 08:44 PM
Discussion 9.5 inch wingspan Dash 8-100 Joe Malinchak Scratchbuilt Indoor and Micro Models 8 Aug 27, 2012 01:09 AM
Gallery Dash-8-100 doc-e Your Plane Photos 0 Sep 14, 2005 09:15 AM
