Aug 26, 2019, 11:40 AM
iCharger 106B+ processor & firmware encoding
Hello everyone,
I am looking for detailed information regarding the iCharger 106B+. In particular I am looking for...
1) the processor used in the iCharger 106B+ and
2) information regarding the firmware encoding.
Why? Because I would like to modify the latest V3.14 firmware to lower the LiPo storage voltage to 3.72 volts.
Best regards,
Chris
Aug 26, 2019, 02:48 PM
If you use LiIo storage (3.75V), you're pretty close. Or use the Discharge program when the battery is charged.
Aug 26, 2019, 03:04 PM
Keep Flying Model Aeroplanes
Rhea's Avatar
Discharge function will take it to 3.72V.
And of course you will be discharging it to that voltage since you would never have discharged it to a lower voltage in the first place because it would not be good for the battery.
Aug 26, 2019, 03:27 PM
RNFLY,
uh that's a great idea with the LiIo storage program. Thanks a lot for this nice tip. Will definitaly try this out the next time. Discharge is also nice, but I would like to have a program which is automatically deciding whether to charge or discharge - depending on the battery status.
Nevertheless - just for fun I would still be interested in hacking the FW to set a native 3.72V if someone has any info here. At the end, we are all hobbyists, always in search for the optimum :-)
Alternatively @Junsi is welcome to provide a "beta" firmware ;-)
Best regards,
Chris
Aug 26, 2019, 04:45 PM
Rhea's Avatar
If you can do what you want to do be sure to let us know how it goes.
I am not completely satisfied with Storage voltage either but I don't use that function anyway. I will just fly for a time that will leave the battery voltage near a good storage level. That is usually around 3.85V/cell.
Aug 26, 2019, 04:46 PM
Rhea's Avatar
RCG had a glitch that caused a double post.
Oct 20, 2019, 02:04 AM
icharger modified firmware
Look here for a modified firmware. You can make your own changes and do your own build. I know the icharger 106B+ is not directly listed here, but a read through the comments will point you in the right direction.
https://github.com/stawel/cheali-charger
If you icharger is an older ones 2008 ish, then you may have this CPU
https://groups.google.com/forum/#!se...g/W-YhsbhLCwAJ
If you open the unit up, most likely they have tried to scrape off the MPU/MCU label, but sometimes there is enough left over to verify the maker. Also looking at the packaging is another way. For example, the SyncMos units are a bit taller with the dot representing pin 1 in the middle of the slanted side, verse the Atmel version where the dot is on the top of the package. Each manufacturer had a slight difference in packaging that can help you narrow down the make and model.
Discussion Icharger 106b up in smoke wildpede Batteries and Chargers 6 Jun 19, 2016 10:53 AM
Question iCharger 106B+ replacement switch Rhea Batteries and Chargers 1 May 06, 2016 03:01 PM
Question Icharger 106B+ for NiMH batteries jpurcha Batteries and Chargers 2 Apr 23, 2016 05:24 PM
Discussion Faulty icharger 106B+? Techyguy90 Beginner Multirotor Drones 0 Oct 21, 2015 10:28 PM
Help! Icharger 106B firmware update gustavo_123 Batteries and Chargers 8 Feb 17, 2012 07:13 AM
