Aug 25, 2019, 12:55 PM
Brushed fc problem
Hello every one
I have an brushed micro drone didnt use it from 1 years at least
Spracing f3 brushed
8520 motor
65 prop
100 frame
1s 700mah lipo
Rx2a receiver
I have a caddx micro cam from old crashed drone this morning i take it to install it in that micro drone after i go to cleanflight try to conect it told me the firmware is too old
I flashed the last firmwere on it and configure every thing
When i go to fly the drone wont lift off more then 30 cm from the ground all position look good
Yaw pitch roll
I feel the drone response to throttle like max 1200 mid throttle and max nothing happen
So i tryed every thing that is possible to cause that problem but i fail
I check min an max all
I set motor in cli : set motor_pwm_rate= 1000 and 2000 and 16000 and 32000
Nothing changed
Tryed to enable and disable every option in config page nothing changed
Try also ppm receiver mode and sbus
I changed the 4 motor
I removed some grams the frame top and came only the motor and frame plate
Nothing changed
I can just throw this drone no need it any more but i cant do that before i know what that problem is
Edit : i flashed betaflight on it also didnt work
Idea Brushed 2ch plane from Brushed FC ccatalin Micro Multirotor Drones 4 May 03, 2017 06:41 AM
Discussion Maker Fire F3 Brushed FC Problem CaptainPasty Micro Multirotor Drones 0 Mar 06, 2017 10:25 AM
Discussion Problems with Eachine Micro F3 Brushed FC (FRF3_EVO) quarkburger Multirotor Drone Electronics 2 Feb 04, 2017 11:37 AM
Discussion Eachine Micro 32b F3 brushed FC problems Mr_Stian Multirotor Drone Electronics 2 Nov 24, 2016 01:36 AM
Question BRUSHED ESC throttling problems (problem solved) Artful Owl Power Systems 3 May 05, 2016 12:28 AM
