Aug 25, 2019, 11:02 AM
Stits painting over a canopy
I have built a shoestring from scratch and am using the Stits lite system. I would like top know if anyone has painted their canopy with Polyspray followed by Polytone paint. I used a little Ploybrush on the canopy and it didn't seem to attack it
Aug 26, 2019, 08:40 AM
anyone?
Aug 26, 2019, 02:51 PM
k2k
k2k
k2k's Avatar
I have done several planes in Stits Lite and the Polyfiber paint system but I have not tried to do that. Looking through the manual there is no mention of using Polyspray on plastic, or for that matter any of their products. I think that what will probably happen is that it will peel off over time. The manual does describe using their primer and enamal paints on metal and fiberglass. I think your best results might be to use a primer for plastic like Tamiya then use the matching Polyfiber enamal on top of that.
Aug 26, 2019, 03:04 PM
k2k
k2k
k2k's Avatar
Call F&M Enterprises, they should know what to use.
Oct 08, 2019, 12:28 PM
Whether I'm using dope or epoxy paint, when I spray plastic of any kind I always fog on a few coats to let it sort of build up the finish kind of dry. That way most of the solvents are dispersed in the air before it hits the plastic. After the color is on pretty good you can put down one slightly heavier coat but don't get happy with it.
And it's always a good idea to do an acid test on a piece of scrap material before hand.
carl
Discussion San Francisco School Painting Over 1936 Historic Mural that was Painted by a leftist Gooroo Life, The Universe, and Politics 20 Aug 05, 2019 05:44 AM
Question Can you paint with house of kolor (HOK) over monokote. HAWKEYE44444 Painting and Finishing Tips 1 Apr 06, 2016 09:55 AM
Discussion Testors Model Master Paint over Monokote Shamus 1102 Scale Kit/Scratch Built 8 Feb 10, 2016 01:28 AM
Question Painting a White over olive drab covering p3arljam Painting and Finishing Tips 1 Jan 29, 2016 09:50 AM
Question Question on painting over covering Stephen M Painting and Finishing Tips 1 Nov 10, 2015 11:15 PM
