This thread is privately moderated by CorsairFlyer271, who may elect to delete unwanted replies.
Aug 24, 2019, 08:24 PM
Trader Rating: 3
CorsairFlyer271's Avatar
$90.00 USD
Will not ship
Sold
H-King Focke Wulf-190 1200mm (EPO)
Selling my H-King FW-190 47" plane. Only a few flights. Great condition. You can fly on 3S or 4S; includes HK 45A ESC with built in BEC. Sold with no receiver, but I have a LemonRx 7-ch Stabilizing Plus (+) receiver installed. If you have a Spektrum transmitter and want the receiver too since it's all set up add $20.00. I can copy the model onto your SD card. No shipping sorry. Flys great. Retracts, LEDs, scale appearance.
Manufacturer specs below.
https://hobbyking.com/en_us/h-king-f...m-epo-pnf.html
Features:
Easy and Fast Construction
Uses 2200mAh 4s Lipoly Battery for excellent flight performance
Capable of performing inverted flight, inside/outside loops, axial/barrel rolls and scale like flying routine
High quality and extremely robust scale molded spinner, cowl and battery hatch
Large stable design and it flies like it is on rails
High compression ration EPO foam material means stronger airframe and high detail scale finish
Electronic retractable landing gear with scale struts installed and sequenced gear doors
Scale cockpit with detailed instrument panel decals
A pre-painted lifelike pilot
Big operational and powerful split flaps make landing a breeze
Robust and scale 3 bladed propeller
Tiny fan blades have been molded to the spinner backplate which draws more air into cowling for effective motor cooling
Specs:
Wingspan: 1200mm (47.2")
Length: 1020mm (40.2")
Flying Weight: 1600g
Motor: Sunnysky 3120 680KV
Propeller: 3-blade 12x8
ESC: 45A w/BEC
Servo: 9g x 7
Retracts: Servoless Electric with scale struts
Gear Doors: Sequencer/Servo Controlled
Requires:
Your Own 6 Channel TX/RX
2200mAh 4s or 3s 25C Lipo Battery
Aug 24, 2019, 09:03 PM
Trader Rating: 7
Trade for a c47 PNP?
Aug 24, 2019, 09:17 PM
Trader Rating: 3
Thanks, but I'm trying to downsize hanger. Too many now. LOL.
Aug 24, 2019, 09:28 PM
Trader Rating: 7
Dang no problem. Figured id give it a shot I'm local
New Product H-King Focke-Wulf FW-190 1200mm Andy852 Electric Warbirds 42 Aug 06, 2019 05:06 PM
New Product The H-King Focke Wulf FW-190 Butcher Bird 1600mm Andy852 Electric Warbirds 46 May 04, 2019 09:49 PM
Sold Focke-Wulf Fw-190 1200mm (47.2") EPO festooks Aircraft - Electric - Airplanes (FS/W) 2 Jun 29, 2018 10:55 AM
