Oct 14, 2019, 02:08 AM
ok.
some thinking about the upward thrust angle
of the exhaust of this mirage.
The motor of My Wattage Mirage 2000 requires some upward thrust angle, it is a pusher. Also it
requires some reflexes on the ailevons.
So I guess this Mirage has some good built in
upward thrust angle, then without any
modifications It will not need any reflexes on the
ailevons at all. All of my delta wing jets with
straight exhaust do need some reflexes on the
ailerons. This stock mirage might need no reflex
on its ailevons at all.
Just a thought.
Oct 14, 2019, 10:22 AM
John Lueke's Avatar
Seems like keeping the large amount of upthrust and no reflex would make the throttle the primary pitch control. I would prefer to use the elevons for pitch. But there probably is an optimum combination of both. That may be why they recommend the vectoring nozzle.
Oct 14, 2019, 11:40 AM
Foam addict
4stripes's Avatar
I have the FlyFly Mirage and the thrust is straight out the back. With the CG I fly with there is no deflection in the flight controls to maintain level and no appreciable throttle/pitch coupling. I think this kit has gone way too far by angling the nozzle up.
Good thing it is foam and easy to correct.
Oct 14, 2019, 11:46 AM
Gorilla Glue Expert
PikeStaff's Avatar
Yep. Mine too. Had an old G&C 64mm Mirage once, it was straight aligned. And, of course, the Freewing is also. Cannot see any cause to have angled this up the way it is; even with vectoring. All that will do is induce some pressure/velocity loss when straightening out the exhaust stream for flat and level flight.
Nope, think John has it right with his printed collar. Mine will simply get cut for re-alignment as I still live in the 20th century.
Oct 14, 2019, 12:01 PM
John Lueke's Avatar
I am still working on the print parameters to get a little bit of warpage out of the wedge. You can see it in the picture. It works but leaves a gap. A little work on a belt sander could make it better. So if anyone is interested in the green parts, I would let you have them for the cost of shipping.
Oct 15, 2019, 01:57 AM
edwen303's Avatar
I agree with 4Stripes and Pikestaff on the thrust angle.
Now I wonder if there is something off with the leading edge of this Mirage. Like Pikestaff also mentioned earlier, the bottom of the wing is almost completely flat, unlike the almost symmetrical LE for FF or FW Mirage.
Oct 15, 2019, 02:24 AM
Just take a look at my wattage Mirage 2000 pusher.
Flat bottom wings, has upward motor and
needs reflex ... very similar to this mirage.
wonder if those Chinese flyers modified
their mirage like we do ? Those dudes
are weird... very poor with communication.
Oct 20, 2019, 02:31 PM
edwen303's Avatar
Looks like a great day for the Mirages:
Another maiden with 70mm FMS fan. Looks like the kit we discuss here:
小張 90mm 幻象白機 + FMS 70mm 3060 1900kv動力 首航 (3 min 13 sec)
Oct 20, 2019, 02:36 PM
edwen303's Avatar
Maiden with Freewing 80mm 9 blade fan. At 9" of this video, there appears no upthrust in the model :
阿勇 90mm幻象白機 + 80mm Freewing 9葉動力 飛行 (2 min 54 sec)
Oct 20, 2019, 02:46 PM
edwen303's Avatar
Another maiden: No upthrust in the model either.
阿國 90mm 幻象白機首航成功 (2 min 35 sec)
Oct 20, 2019, 03:12 PM
seems there are two versions of
this mysterious Mirage :-)
And The mirage we are buying is not
the mirage they tested in videos :-(
Maybe what we got is the prototype :-(
Oct 20, 2019, 04:54 PM
Gorilla Glue Expert
PikeStaff's Avatar
Mmmmm.....
I wonder. None were hurting for thrust..... the ones we got surely will without mods. Theirs all have gear doors - something they added?
They look the same. Wonder where they set CG? - the 80mm had the batt in the cockpit.
Questions, questions.
Oct 30, 2019, 02:54 AM
Have anyone covert it to turbine version, I have one in the box
Nov 04, 2019, 01:23 PM
some more pics i found off the net.
Nov 04, 2019, 02:04 PM
Gorilla Glue Expert
PikeStaff's Avatar
Nice find - lots of good info in those pics! Thanks for posting those up.
New Product HSD 90mm F86 kit on Aliexpress... 4stripes Foamy EDFs 51 Oct 23, 2019 07:23 PM
Discussion buy goods from Aliexpress lovecat063 Vendor Talk 9 Nov 24, 2017 11:03 AM
Discussion Anyone know what the CG is on FlyFly Mirage 90mm Robert Boudreau Electric Ducted Fan Jet Talk 4 Feb 03, 2016 05:50 PM
