Aug 25, 2019, 04:00 AM
jofro
Forget about Aspirin! Try it on some 10-12G strand wire, waste of time. Bit of soak in Acetone will also help to remove it if you un-twined the strands.
Aug 25, 2019, 09:37 AM
pull up -- PULL UP!!!
So positive and negative votes on aspirin.
What about heat? Anyone find that directed flame or extra hot iron was unable to remove the coatings?
Aug 25, 2019, 01:07 PM
Click here to block ads
Ron H's Avatar
I have had a little luck with heat and a little with solvents. Scraping works 100% of the time.
Aug 25, 2019, 01:48 PM
If it flies, I can crash it.
rocketsled666's Avatar
The results achieved with any solvent will depend on the solvent and what's being dissolved. Since no one knows what the insulation on their magnet wire really is, and there are many types of insulation all of which look pretty much the same, the method used in any one case may or may not be applicable to any other.
However, as mentioned by me and a few others, heat absolutely will remove any coating from the wire no matter what it's made from. You can accomplish this with a lighter or a candle, but the preferred method is a small butane torch (or a lighter of that style). Burn off the insulation, then wipe down the wire to remove the carbonized remnant material. Grab the wire below the point you want to bare with a pair of needle nose pliers to act as a heat sink, so you don't heat up more wire than you intend to.
Aug 27, 2019, 04:12 AM
jofro
I agree, use of an open flame like mini butane torch is another great option if you un-twine the strands and remove coating with mini wire brush.
Help! Motor Wires (GARTT ML2206S 2000KV) Won't Tin - Can't Solder questech Electric Motor Design and Construction 16 Apr 22, 2016 05:31 PM
Discussion Soldering motor wires cootertwo Beginner Multirotor Drones 9 Apr 05, 2016 01:26 PM
Discussion Soldered motor wires in reverse (Easy way out? ) DroneRequired Beginner Multirotor Drones 5 Mar 21, 2016 03:55 PM
Discussion ready to sky motor wire wont solder shalersrs Beginner Multirotor Drones 5 Jan 21, 2016 04:41 PM
Discussion How do I solder motor wires to ESC wires? (different gauges) eMikey Power Systems 3 May 14, 2014 10:03 AM
