This thread is privately moderated by kopterheld, who may elect to delete unwanted replies.
Aug 22, 2019, 08:44 PM
Mini-Review
HX100 micro FPV Racing - BetaFPV
Get the HX100 fromAmazon
https://amzn.to/30VZNSd or from BetaFPV http://bit.ly/HX100xm
Get 10% BetaFPV Site Coupon here -http://bit.ly/KHBetaFPV
I am very satisfied with the HX100.
100mm carbon fiber frame, weight: 44g, 1103 8000KV motors, 65mm and 48mm propellers, F4 FC with 2-4S 12A and the good Runcam Nano2.
He flies perfectly and you get all the spare parts shipped quickly at Amazon DE. The HX100 is really fast which I would recommend to experienced pilots. For the FPV entry I still recommend a Tiny Whoop like Eachine Trashcan or Beta75X 3S or the new Beta85 Pro 2.
Pic 1,2 - The video antenna is placed upwards. Here's a little hole in the camera canopy
Pic 3 - Stiffer propellers use the HQ Prop 65mm
Pic 4 - CrossFire Receiver antenna attached with cable ties to the arms
Pic 5 - CrossFire receiver soldering to TX and RX on the newest BetaFPV F4 12A ESC AIO board
Pic 6 - FrSky XM receiver soldering to SBUS on the BetaFPV F4 12A ESC AIO board . For R-XSR with telemetry you can use the TX solder pad for the sport cable and use SOFTSERIAL on Betaflight with this two changes
resource SERIAL_TX 2 NONE
resource SERIAL_TX 11 A02
Pro:
- lighter 2.5 inch FPV racer
- Good Runcam Nano 2 camera
- strong VTX 25-200mW
- very good engines 1103
- F4 board 2-3S 12A ESC's
- external receiver such as CrossFire
Cont:
- not configured correctly
- Camera canopy a bit too loose
- Video antenna too low
- Motor arms a bit thin
My review video (EN subtitle):
HX100 from BetaFPV
HX100 Mikro FPV Racer von BetaFPV (6 min 41 sec)
Suitable batteries:
GNB 300mAh 3S 30C
Banggood - http://bit.ly/Gnb300mAh3S
Amazon - https://amzn.to/2xg3kOx
Happymodel 300mAh 3S 30C
Banggood - http://bit.ly/M7Hd300mAh
Amazon - https://amzn.to/2IQ4zdY
BETAFPV 300mAh 3S 45C - https://amzn.to/2ZkvZS7
GNB 300mAh 2S 45C - Amazon - https://amzn.to/2S6C26U
GNB 450MAH 2S 80C -
Banggood - http://bit.ly/GNB2S450mah
Amazon - https://amzn.to/2Wq1WU1
Turnigy Nano-Tech 300mAh 3S 45C - HobbyKing - http://bit.ly/2AHM5YR
Propeller:
HQ Prop 65mm - Banggood -http://bit.ly/HQProp65mm
My fixes:
1. Settings taken from my Reddevil / SailFly-X with Beta 4.0.5
2. Propeller running direction as in Reddevil / SailFly-X set up, so normal spin direction to the camera canopy
3. Stiffer propeller uses the HQ Prop 65mm 1.5mm Shaft Banggood -http://bit.ly/HQProp65mm
4. The video antenna is placed upwards. Here a small hole in the camera hood attached
5. CrossFire Receiver antenna attached with cable ties to the arms
Good Tiny Whoops with 2S I recommend for FPV beginners:
Beta85 Pro 2- Amazon - https://amzn.to/2Y33Mj7
Beta75X 3S - Amazon - https://amzn.to/2Jv910i
Beta75X HD - Amazon - https://amzn.to/2MQ3W6p
EMAX Tinyhawk Freestyle - Banggood - http://bit.ly/TinyHawkFreeStyle
My configuration . The PID's are from SailFly-X to fly 3S Lipo with Rate1 profile and for 2S Lipo with Rate 2 profile. PID's setting are from Albert Kim Betaflight 4.0 PID Tune for Sailfly-X
I have installed Betaflight 4.0.5 to the HX100 with this changes:
# diff 2019-08-21
# Betaflight / MATEKF411 (MK41) 4.0.5 Aug 1 2019
batch start
name HX-100
feature -SOFTSERIAL
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -CRASH_FLIP
beacon RX_LOST
beacon RX_SET
serial 0 2048 115200 57600 0 115200
serial 1 64 115200 57600 0 115200
led 0 0,0::A:0
led 1 1,0::A:0
led 2 2,0::L:0
led 3 3,0::L:0
mode_color 6 0 2
aux 0 0 0 1700 2100 0 0
aux 1 1 1 900 1300 0 0
aux 2 2 1 1300 1700 0 0
aux 3 13 2 1700 2100 0 0
aux 4 35 2 1700 2100 0 0
aux 5 47 2 1300 1700 0 0
set gyro_lowpass2_type = BIQUAD
set gyro_lowpass2_hz = 0
set dyn_lpf_gyro_max_hz = 800
set acc_calibration = -38,41,34
set baro_hardware = NONE
set min_check = 1010
set max_check = 2000
set serialrx_provider = CRSF
set dshot_idle_value = 400
set motor_pwm_protocol = DSHOT600
set vbat_max_cell_voltage = 460
set vbat_min_cell_voltage = 310
set vbat_warning_cell_voltage = 320
set beeper_dshot_beacon_tone = 5
set small_angle = 180
set deadband = 4
set yaw_deadband = 4
set pid_process_denom = 1
set osd_warn_batt_warning = OFF
set osd_warn_core_temp = OFF
set osd_vbat_pos = 2497
set osd_rssi_pos = 289
set osd_tim_2_pos = 2519
set osd_flymode_pos = 409
set osd_throttle_pos = 353
set osd_crosshairs_pos = 270
set osd_current_pos = 417
set osd_mah_drawn_pos = 440
set osd_craft_name_pos = 2507
set osd_warnings_pos = 14761
set vcd_video_system = NTSC
profile 0
set dterm_lowpass2_type = BIQUAD
set dterm_lowpass2_hz = 150
set vbat_pid_gain = ON
set feedforward_transition = 30
set iterm_relax_type = GYRO
set iterm_relax_cutoff = 11
set p_pitch = 29
set i_pitch = 85
set d_pitch = 30
set f_pitch = 95
set p_roll = 24
set i_roll = 78
set d_roll = 26
set f_roll = 90
set p_yaw = 55
set i_yaw = 55
set d_yaw = 8
set f_yaw = 25
set angle_level_strength = 65
set horizon_level_strength = 65
set level_limit = 75
set d_min_boost_gain = 30
set d_min_advance = 0
rateprofile 1
set roll_rc_rate = 120
set pitch_rc_rate = 120
set yaw_rc_rate = 130
set roll_srate = 75
set pitch_srate = 75
set yaw_srate = 80
set tpa_rate = 80
set tpa_breakpoint = 1700
rateprofile 0
set roll_srate = 75
set yaw_srate = 80
set tpa_rate = 80
set throttle_limit_type = SCALE
set throttle_limit_percent = 75
batch end
More Coupons:
http://bit.ly/KhFaceBo
https://kopterheld.wordpress.com/2018/01/01/news/
Or Telegram App:
https://t.me/KopterHeld
My Equipment:
Fatshark Dominator HDO - http://bit.ly/BgFaHDO
ImmersionRC RapidFIRE - http://bit.ly/BgRapidFire
Eachine Pro58 Achilles - http://bit.ly/EaPro58
FrSky TARANIS Q X7 - http://bit.ly/2zLLvJq
FrSky X9D Plus SE - http://bit.ly/2z4KxXG
FrSky Taranis X-Lite - http://bit.ly/BgXlite
iRangeX IRX4 Plus Multi Modul - http://bit.ly/2QrTIeT
FrSky R-XSR - http://bit.ly/2S6rNyc
RunCam Split Mini 2 - http://bit.ly/2SKjCMQ
RunCam Racer 2 - http://bit.ly/2BZJCtq
RunCam Micro Eagle - http://bit.ly/2BPNnkL
Youtube https://www.youtube.com/kopterheld
FaceBoo http://bit.ly/KhFaceBo
Blog https://kopterheld.tv/
RCGroups https://goo.gl/JYP87D
Telegram - https://t.me/KopterHeld
Instagram - https://instagram.com/kopterheld
Twitter - https://twitter.com/kopterheld
Support me on your next purchase on Banggood or Gearbest
Banggood - http://bit.ly/khBanggood
Gearbest - http://bit.ly/khGearbest
New Product BetaFPV HX100 100mm MultirotorDrones Micro Multirotor Drones 82 Sep 11, 2019 09:52 AM
Discussion HumQuad HX100 100mm FPV Racing Drone AIO F4 12A Flight Control A01 VTX Run Cam Nano V scousethief Geekbuying.com 15 Aug 19, 2019 05:46 AM
