Aug 22, 2019, 07:32 PM
The "Rudy "of RC
A little help with a big twin
Got beautiful twin on a trade and don't really know what it is. Has about 10 flights from a huge plane. Swings a 2610 and tons of compression. The CH ignition module is not in the picture. Anybody know some specs on this? Much appreciated...
Aug 23, 2019, 06:23 AM
KMatch's Avatar
It's another case of someone taking readily available cylinder/piston assemblies and machining a case and crank to fit them. Some small companies like HHT did this as well as home hobbiests. Due to the fine machine work I believe this was an actual produced model and not a hobby. HHT cylinders and such are replaceable with "pit bike" parts on ebay. Due to these extra blocked off intake ports on yours it's a different set but still likely available if needed. Crankcase parts are likely long gone though.
https://www.ebay.com/itm/44mm-Cylind...r/262705169430
Aug 23, 2019, 06:29 AM
earlwb's Avatar
Several businesses and companies made airplane engines, by machining new crankcases for cylinders and parts from existing engines. It is difficult to identify an actual company that made it as so many had done it. Unless had they left identifying marks on the engine somewhere.
Aug 23, 2019, 07:29 AM
The "Rudy "of RC
Hey guys. I kinda thought that. The crankcase is polished aluminum that looks like it was not hard to make with the reed valve and a bigger walbro carburetor mounted between the 2 cylinders. It looks like it would be in the 80-90 cc range and is almost scary when it's running as I have always been a smaller glow guy in the .40.
Thanks for your help...
Discussion Little motor, big problems with Castle Talon seng30904 Castle Creations 1 Feb 04, 2019 03:58 AM
Discussion A push/pull twin with really big flaps! Quorneng Foamies (Scratchbuilt) 1 Dec 21, 2015 10:17 AM
Discussion Okay, a little help here with a big wing gfulton Foamies (Scratchbuilt) 7 May 28, 2010 05:43 PM
Big Herc needs Little Help sparks Scale Kit/Scratch Built 9 Jan 28, 2002 06:47 PM
Big Herc needs Little Help sparks Power Systems 4 Jan 27, 2002 09:46 PM
