1/10 GRANITE MEGA 550 Brushed 4WD Monster Truck RTR (ARA102714T1)
Built for monster truck bashing straight from the box, the rugged 1/10 scale ARRMA GRANITE 4X4 MEGA 550 comes fully equipped for all-terrain fun - and includes a Spektrum STX2 2.4GHz radio system for the ultimate in precise, dependable control.
GRANITE 4X4 MEGA RTR
Fast and fully equipped, the 2S LiPo-compatible GRANITE 4X4 MEGA RTR arrives ready-to-bash in all-terrain. It's MEGA 12T 550 brushed motor gives you the muscle to reach maximum speeds. Waterproof* electronics make it ready-to-run in any type of weather. dBoots® Fortress tires supply the traction to take on any surface. The included Spektrum STX2 radio with SRX200 receiver offers many of the same features found in high-end 2.4GHz radio systems — throttle and servo reversing, throttle and steering travel adjust, throttle limiting and more — for the ultimate control. Precision aluminum, super-tough steel, and composite materials are all combined in an easy-to-maintain vehicle design that is built for action, straight from the box. Your GRANITE™ 4X4 MEGA Monster Truck will launch you straight into dirt-blasting, rock-crushing fun. Just add four AA batteries and get bashing!
Introducing the ARRMA 4x4 MEGA GRANITE & SENTON (1 min 34 sec)
Features
  • Spektrum STX2 2.4GHz radio
  • 2-Channel SRX200 waterproof* receiver
  • Built-in 3-position throttle limiter
  • Extended range and interference-free performance
  • Throttle/steering reversing
  • Throttle/steering travel adjust
  • Throttle limiting
  • ADS-5 waterproof* 5kg-cm servo (70 oz-inch @ 6V)
  • MEGA 12T Brushed 550 motor
  • MEGA waterproof* ESC
  • IC3™ connectors (EC3™ compatible)
  • Easy-access power module
  • Easy-access electronics module
  • Easy-access diff module removal front and rear
  • Oil-filled shocks
  • Super-smooth bearings
  • Super-tough metal gears
  • Tough multi-spoke black wheels and multi-terrain dBoots® Fortress tires
  • Adjustable body mounts
  • Adjustable ride height
  • Extended height dirt defenders
  • 2400mAh 8.4V 7-cell NiMH battery
  • ADC-N7 7-cell NiMH wall charger
  • 30 mph (48km/h) speed achievable in optimum driving conditions with optional gearing
  • Waterproof*
  • 2-year limited warranty
Powered by the MEGA 550 brushed motor system, the ARRMA® GRANITE 4X4 MEGA RTR Monster Truck is DESIGNED FAST, DESIGNED TOUGH — built for exciting bashing speeds and extreme, all-terrain durability! Its full-time 4WD transmission with front and rear differentials uses strong front, rear, and centerline telescopic driveshafts that can't be lost during heavy impacts, unlike dogbones. A simple, dependable, responsive steering assembly complements the ultra-reliable drive system and features a servo horn with built-in servo saver.
The self-bleeding, oil-filled shocks use a tried and tested, coil-over design for simple maintenance and amazing handling. Their innovative rod end has a molded-in spring perch for extra toughness. High chassis guards limit the amount of dirt and debris that can get into the chassis tub. Shock-absorbing loops keep the front and rear bumpers secured to the chassis, offering defense against heavy impacts.
The GRANITE 4X4 MEGA RTR Monster Truck's ingenious modular design makes chassis components easy to access for maintenance. Its power module consists of a MEGA 550 motor, motor plate, slipper clutch assembly and gear cover. The power module can be detached from the chassis, as a complete unit, by removing just one screw. With the power module removed, the slipper clutch can be reached easily for adjustments by taking out three screws that attach the gear cover. The power module design also ensures that pinion and spur gear mesh is perfect every time, using numbered holes for different pinion gear sizes.
For More Info...
Head over to Horizon Hobby for pricing and more!
Mini-Review HG P104 1/10 2.4G 4WD 25km/h Rc Car Knight 550 Brushed Big Foot Off-road Truck RTR Merch Off-road Cars 3 Nov 21, 2018 04:24 PM
Mini-Review HNR MARS (H9801) 1/10 RTR 4WD Brushless Monster Truck at $203 hbx12891 Off-road Cars 70 Oct 22, 2018 03:53 AM
Discussion HG P104 1/10 2.4G 4WD 25km/h Rc Car Knight 550 Brushed Big Foot Off-road Truck RTR To scousethief Banggood.com 0 Aug 13, 2018 05:30 AM
Discussion Exceed RC 1/10 2.4Ghz Short Course Monster Nitro Gas Powered RTR Off Road 4WD Truck C Nitro_Nancy Vendor Talk 0 Apr 27, 2018 04:33 PM
