This thread is privately moderated by DutchRC, who may elect to delete unwanted replies.
Aug 22, 2019, 09:05 AM
my RC. Your info
DutchRC's Avatar
DutchRC Ripley - Ultimate 6S Freestyle FPV Quad
Halloa people
sooo yes.. allmost unbelievable but here is another build project from me.. I've been working (selecting parts etc) on this one for several months....
I am in the process of replacing my 4S (GepRC KHX5 Elegant) freestyle quads with fresh 6S versions in this thread I'll show you the "Why & How" of this project...
I'm actually going to start this story with 2 first flight tests!
Later on I'll tell you what parts I used and WHY I chose those......
DutchRC RIPLEY - Ultimate 6S Freestyle FPV Quad - P1: Test Flights (14 min 4 sec)
Parts list:
Frame: Speedybee 5" 225mm
Stack: Diatone Mamba F722S + 6S 4-in-1 Dshot1200 ESC
Motors v1: iFlight Xing 2207 1800kv
Motors v2: Racerstar SIC 2207 1888kv
Props: Gemfan Windancer 5043
FPV camera: Runcam Racer 2 black 2.1mm
FPV transmitter: Rush Tank VTX
Control receiver: FrSky R9mm
The lipo's I'll use: Gaoneng GNB 1100mah 6S 130C
Aug 28, 2019, 09:03 AM
my RC. Your info
DutchRC's Avatar
Allright.. time for a bit more detail / info on this project then! Here is a quick (as quick as I can / want :P) overview of all the parts AND the why of those parts
DutchRC RIPLEY - Ultimate 6S Freestyle FPV Quad - P2: PARTS USED (18 min 43 sec)
Sep 02, 2019, 09:34 AM
my RC. Your info
DutchRC's Avatar
And yes.. one of the first parts you select when starting a build-project is...
The quad's frame
SpeedyBee 5" Frame Review - DutchRC RIPLEY - Ultimate 6S Freestyle FPV Quad - P3 (22 min 4 sec)
wheelbase: 225mm
base thickness: 5mm arms
material(s): carbon fiber and alluminium
weight: 110 grams
chamfered edges: YES
clean: 100% clean
buzzer: nope
LED board: nope
battery strap: yes, stiched; anti slip; metal buckle
battery anti-skid pad: yes
Sep 10, 2019, 09:03 AM
my RC. Your info
DutchRC's Avatar
Sooooo obviously these freestylers need a BRAIN! And not just any.. I basically use F7's for all my quad builds.. Allso: I use Mamba / Diatone stacks in most cases..
Let's have a close look at the Mamba F722 Super Stack!
Diatone Mamba F722S 6S STACK REVIEW - Ultimate 6S Freestyle FPV Quad - P4 (16 min 21 sec)
Specifications of the stack:
ESC size: 36.5 x 46.5 mm
FC size: 37.9 x 37.9 mm
mount: 30.5 x 30.5 mm mounting pattern
continuous A: 4 x 50 = 200A
BEC: 5V 2A & 9V 2A
peak A: 4 x 55 220A (10 seconds)
Voltage: max 6S ( 7.4V - 25V)
protocol: Dshot300 - 1200
ESC processor: 32 bit
stock BF version: 3.5.5
OSD: yes
flash: yes, 16 MB
Discussion Motors for 6" Long Range / Freestyle Quad (on 4S and 6S) - Recommendations UFOking Multirotor Drone Power Systems 3 Aug 28, 2018 02:43 AM
Mini-Review XHover Stingy FPV Freestyle Frame Unboxing -- A Noobs first fpv quad build joecec FPV Aircraft 1 Sep 17, 2017 05:20 PM
Discussion Lets build the Ultimate Freestyle quad!!!!! joe.ismail FPV Aircraft 3 Sep 22, 2016 02:16 AM
Video FPV Quad Freestyle at the UK BMFA Nationals 2015 DominicM Multirotor Drone Talk 0 Dec 05, 2015 03:40 AM
