Aug 21, 2019, 03:51 PM
FASST flyer
KatManDEW's Avatar
Where to get power for BEC?
Where are you picking up the input power for BEC's? I've tried getting it from the main battery connection and the balance plug, as in the attached photos.
Aug 21, 2019, 04:37 PM
Either method should work, but the left-hand photo looks a little suspicious. The balance connector on any battery pack is always wired in cell order, so full battery voltage will appear ONLY on the two outer pins. Your photo shows the JST connector wired to two ADJACENT pins, so you're picking up the voltage of a single cell rather than full pack voltage. For the typical BEC, the minimum input voltage is 2 cells. Also, be sure the polarity is correct.
Aug 21, 2019, 05:00 PM
FASST flyer
KatManDEW's Avatar
Bad photo. If you look close you will see it is picking up from the two outer pins. Sorry about the poor photo.
Aug 21, 2019, 11:03 PM
Wintr's Avatar
How much current is the BEC rated for? The balance connector is limited to only a few Amperes.
Aug 22, 2019, 07:50 AM
FASST flyer
KatManDEW's Avatar
I can't remember for sure, but I'm pretty sure it's a 5 amp BEC. That's 5 amp BEC output, at 5 volts. So 25 watts. Input voltage from a 6S pack is ~22 volts, so 25 watts at ~22 volts would be roughly 1.2 Amperes, right?
On aircraft larger than 6S I don't use the balance connector for BEC power. I have used various methods of tapping power from the main battery circuit.
Do you pick up your BEC power at the main battery connector?
Aug 22, 2019, 08:18 AM
At 5 amps, I would connect the BEC to the power leads instead of the balance leads. Although the input current won't be 5 amps if the output is 5 amps. It will be lower by about the ratio of the input to output voltage.
Aug 22, 2019, 09:45 AM
Custom User Title
Yes. On the ESC side, that is. I solder another set of wires in parallel with the wires that feed the ESC. That additional set of wires end in some sort of connector, usually JST-RCY because they're readily available with pigtails already attached.
Something like the attached picture. This, of course, adds another possible point of failure, and doesn't give any redundancy against main plug failure. But I can live with that.
Aug 22, 2019, 09:58 AM
Wintr's Avatar
Just to add, no supply is 100% efficient, so input power would be closer 31W at full load; still only about 1.4A, though. Close enough that surges in power draw by a strong servo could cause a drop in power available to the BEC, so I'd use the main power connector, too.
Aug 22, 2019, 02:02 PM
I wire my BEC directly to the ESC's battery plug. It means only one plug to connect when I'm ready to fly. I don't like the extra plug in the photo in post #7 because it's one more potential failure point
Aug 22, 2019, 03:06 PM
GeoffS's Avatar
Slightly off-topic: remember it's best to have only one ground/negative wire going to each component.
For example, I have a battery-voltage monitor connected to my RX.
The RX get's its power and ground from the BEC in the ESC via the 3-pin connector, so I have just one wire from the battery positive connection to the RX's voltage sense pin.
It's not instantly fatal to have multiple ground connections, but "ground loops" like that can generate some of the most difficult-to-troubleshoot bugs.
Aug 22, 2019, 05:31 PM
FASST flyer
KatManDEW's Avatar
That's basically how I do it, except that I do it on the battery lead, as in my photo. That allows me to easily power up the BEC and aircraft, without the motor, to check out everything safely without the motor armed. The BEC's are usually located somewhere such that would not be possible to do that with the BEC wire connected to the ESC connector.
I use Mini Deans for the BEC connector, as in my photo.
Thanks for the feedback.
Aug 22, 2019, 05:45 PM
pull up -- PULL UP!!!
I attach to the esc power wires, but not to the connector pins because I find that a pain.
Instead, I shave away some insulator jacket an inch or two back from the plug and solder the bec power leads to the exposed copper. And then of course cover the splices with HST.
Aug 22, 2019, 07:36 PM
FASST flyer
KatManDEW's Avatar
Yes it is a pain. I was wondering if there was a better way that I overlooked.
Thanks for the suggestion!
Aug 23, 2019, 11:46 AM
https://graysonhobby.com/deans-bec-lighting-tap.html
I've used these connectors on a couple of planes to hook up a BEC and they worked great.
Aug 23, 2019, 03:31 PM
FASST flyer
KatManDEW's Avatar
Perfect! Thank you!
Discussion So few ESCs with BEC...where are you getting 5v for your FC? krachall Beginner Multirotor Drones 6 May 23, 2016 02:28 PM
Discussion Where to get a power pod (for electric motors)? grønnskolling Scale Sailplanes 13 May 03, 2011 06:43 PM
Discussion Any know where I can get parts for the A7 corsair J power that hobbylobby did sale? zach_dad Foamy EDFs 3 Jul 06, 2010 05:08 AM
Discussion Where to get a power pod (for electric motors)? rcer2007 Electric Sailplanes 2 Jan 31, 2007 01:56 AM
Where can I get cell balancing connector matching for my Thunder-power pack? chan Batteries and Chargers 3 Sep 26, 2005 11:01 PM
