This thread is privately moderated by Merch, who may elect to delete unwanted replies.
Aug 20, 2019, 12:57 PM
Merch's Avatar
Mini-Review
Eachine D-moni5 5.8Ghz 72CH 5 Inch 800*480 16:9 Mini FPV Monitor DVR Built-in Battery
Eachine D-moni5 5.8Ghz 72CH 5 Inch 800*480 16:9 Mini FPV Monitor DVR Built-in Battery for RC Drone FPV Racing Drone Car
FEATURES
800*480 display resolution
With memory function, can save the setting when power off.
5 inch small size,easy carry, can be mount on remote controller or used as car monitor.
Single receiver with 72 channels, has covered most frequencies in 5.8Ghz bands
Support DVR function, HD recording resolution at HD(1280*720),D1(720x480),VGA(640X480)
Support video input
Support DC12V external power input
Built-in 7.4v/650MAH battery
SPECIFICATION
Model : 5.8GHz 5 Inch Screen
Channel 72CH
Frequency : 5325-5945Mhz
Recieve Sensitivity : -90DBM
Screen : 5 inch
Type : 16:9 wide
Brightness : 500cd
Resolution : 800 x480
Format : PAL/NTSC
Support SD : up to 32Gb(not included)
Video Compressed Format : AVI
Record Video Resolution : HD(1280*720),D1(704X576),VGA(640X480)
Battery : built in 7.4v/650MAH
Working Voltage : DC12V 300mA
Power Consumption : ≤8.64W
Working Temp. : -10℃ to +65℃
OPERATION
Recording Mode :
C3: start/stop recording
C1 : long press 2 seconds into playback mode
C2 : confirm the playback of files.
Menu Mode :
Long press C2 button 2 seconds into menu;
Then long press C2 button 2 seconds into sub-menu;
Short press C2 1 second to confirm the option;
Short press C1 C3 to select the menu option;
Long press C1 2 seconds to exit sub-menu.
72CH 5.8GHZ FREQUENCY
{5865,5845,5825,5805,5785,5765,5745,5725},//Band A
{5733,5725,5771,5790,5809,5828,5847,5866},//Band B
{5705,5685,5665,5645,5885,5905,5925,5945},//Band E
{5740,5760,5780,5800,5820,5840,5860,5880},//Band F
{5658,5695,5732,5769,5806,5843,5880,5917},//Band R
{5325,5348,5366,5384,5402,5420,5438,5456},//Band U
{5474,5492,5510,5528,5546,5564,5582,5600},//Band O
{5333,5373,5413,5453,5493,5533,5573,5613},//Band L
{5653,5693,5733,5773,5813,5853,5893,5933},//Band H
PACKAGE INCLUDED
1 x Eachine D-moni5 5.8Ghz 72CH 5 Inch 800*480 16:9 Small FPV Monitor for RC Drone FPV Racing Drone Car
1 x Sunshade Hood
1 x Mount
1 x Video Cable
1 x Charger
Aug 24, 2019, 02:38 AM
does this come with diversity? i've been looking at this for a while now but i'm still waiting for reviews, hopefully you or someone can post a review. i really want to have this monitor... compact, built in battery and dvr... hopefully diversity... thanks
Aug 24, 2019, 04:13 AM
Merch's Avatar
It will be here on tuesday i will post a review then.
Aug 24, 2019, 06:12 AM
Merch's Avatar
Ow it came early but im out fur today.
Aug 24, 2019, 04:26 PM
Merch's Avatar
Tested today with great results review to follow only downside is the connectors at the back are RP-SMA female and the monitor does not come with antennas,lucky i had 2 RP-SMA Male dipole antennas to use as this is not a common connector for your goggles or FPV screen.
Aug 24, 2019, 11:38 PM
thanks mate! please send me the link for the review when its available... the only thing that i don't like is the sunshade...it's not as good as the other small monitors out there.. it would be nice if it had the flip sun shade like the other fpv monitors
Aug 24, 2019, 11:39 PM
does it have the bottom nut where you can screw it to a tripod?
Aug 25, 2019, 06:32 AM
Merch's Avatar
No just a small plastic stand with a hole,you would need to bolt it onto a tripod.
Aug 27, 2019, 01:44 AM
Merch's Avatar
Updated with full video review.
Sep 07, 2019, 12:44 AM
thanks for the review mate... and thanks for the details.. i'm not getting one for now because of low quality and glitches :0
Sep 07, 2019, 12:45 AM
subbed on your channel too
Sep 07, 2019, 10:42 PM
Merch's Avatar
Thanks!
Sep 10, 2019, 10:48 PM
Merch's Avatar
Pros:
800X640 screen is nice and clear with adjustable brightness,colour etc
Portable with a built in battery good for on the bench or letting your friends watch you fly
Runtime 140min+
Easy to navigate the menu
DVR recording in (1280*720),D1(720x480),VGA(640X480) with built in playback
72 channels
Great reception even without antennas on
NTSC/PAL auto switch
Sunshade and stand
Cons:
No manual or antennas
The stand is no good the monitor falls over easy
DVR recording stutters no matter what resolution you are recording in FPS is all over the place
HD Recording is stretched not full 1280X720
Connectors at the back are RP-SMA female unusual
Not true HD recording and because of the stuttering DVR playback no matter what SD card you use the monitor is only good to view through plus there is no manual or antennas!
New Product Eachine LCD5800D 5.8G 40CH 7' FPV Monitor with DVR Built-in Battery---Free Testing BGjim FPV Equipment 73 Apr 11, 2017 01:37 PM
