Aug 19, 2019, 11:02 AM
Myles McSwiney
how to unfreeze carbs stuck from fuel.
I have tried every solvent on earth to free up a carb barrel frozen from storage. What free's up a carb barrel frozen from putting away a plane without somehow removing the caster oil left from the fuel drying up? I never expected not to fly it next week but somehow they are stored for longer than expected. then when it go through press flight there it is a frozen carb!!!!!!!!!! 2 cycle or 4 cycle they all freeze up. IS THERE A WAY TO FREE UP THE CARB WITHOUT DISASEMBLEING IT?
Aug 19, 2019, 02:46 PM
Myles McSwiney
Sent from my SM-G950U using Tapatalk
Aug 19, 2019, 06:20 PM
A heat gun works well, or a small propane torch works too so long as you don’t overheat it. If that doesn’t work, try putting it in the freezer for a few hours then hit it with the heat gun or torch.
If that doesn’t work, a cheapo ultrasonic cleaner from Harbor Freight with 50/50 water and Simple Green Pro HD works really well.
Aug 26, 2019, 04:00 PM
BBkilla's Avatar
I would give it a shot of marvel mystery oil after heated up as mentioned.
Sep 09, 2019, 07:23 AM
get some fuel into it... it'll be free in an hour or so.
Discussion How to clean all fuel residues from fuel tank, tubes and engine? muximem Fuel Plane Talk 7 Mar 03, 2019 04:56 AM
Mini-HowTo How to retrieve stuck plane from stadium lamp post vincesd Beginner Training Area (Aircraft-Electric) 28 May 05, 2018 07:55 PM
Question how do you make fuel line clamp from a piece of fuel line?? nakman8 Engines 6 Mar 18, 2010 06:42 PM
Help! Fuel tank distance from carb, CG and frame structures. Rusty-Gunn Fuel Plane Talk 10 Mar 21, 2009 11:32 PM
how do i get my zagi from being stuck in a tree 50 feet high?? compuatic Electric Plane Talk 12 Jun 09, 2002 09:36 PM
